Looking to buy my first Jaguar
Old 03-05-2007, 02:18 PM
bigdreams05's Avatar
Default RE: Looking to buy my first Jaguar
Interior, just the A/C Vents chrome center thing falls off and Yes the tranny is problematic if you don't do fluid changes. The are sealed for life so you would have to take it to a shop and PAY UP! Otherwise a really nice and FAST car with great comfort and difficulty keeping the tires on the asphalt!
Old 03-09-2007, 09:23 AM
I purchased my 2002 3.0 in Ok in Feb.Drove the car home to N.J. without any problem. Love the car.
Old 03-09-2007, 11:22 AM
Congrats. Hope you enjoy it! Stick around and keep us updated if anything comes up!
Old 03-10-2007, 08:59 PM
reddrawf's Avatar
Did you take the plunge? That is a great car. I have a 2003 S-Type v8. I would loved to bought the R but too expensive for me at the time. The R is much faster. That being said, mine is very fast and drives great. I love the car.
To find a Jag club vistit www.jcna.com
I'm a member of the local Jag club here and it has been fun.
Old 01-21-2011, 02:58 PM
1320racer's Avatar
Default water pump & delayed reply to question from reddrawf
reddrawf
While searching water pump failure info for STRs, I just noticed a question for me in this old post. Sorry for the very late response.
In 2008, I did sell my 2000 BMW 540 6speed and purchased a 2005 STR with 7K+ miles. Initially my STR I had some alignment issues, but besides that, I've only performed standard maintenance such as installing a new battery, new brakes/rotors, cleaned air intake sys, change fluids and new filters - - - I did perform the DIY headlight repair a while ago...which is definitely a design flaw.
Today I noticed the smell of antifreeze and then saw steam/smoke a few moments later. Thank goodness I was less than 1/2 mile from my home. After running a coolant system pressure test, I noticed the problem was not a blown hose but rather the water pump had failed. It was extremely difficult to see where the coolant was coming from until the air filter box was removed. I leaned into the engine bay, placed my head where the air filter box was, looked to my left and saw a stream of coolant flowing from the bottom of the water pump's pulley. All the many many many hoses appear to be fine.
My STR just turned 50K miles and at this point I am trying to determine what hoses should be changed along with the coolant system flush, changing the water pump and thermostat.
What else should be done now that everything is torn apart?
Last edited by 1320racer; 01-21-2011 at 06:17 PM. Reason: left out a few words due to typing too fast
Old 01-21-2011, 03:09 PM
androulakis's Avatar
Originally Posted by 1320racer
reddrawf
Today I noticed the smell of antifreeze and then saw steam/smoke a few moments later. Thank goodness I was less than 1/2 mile from my home. After running a coolant system pressure test I noticed that it was not a blown hose but rather the water pump had failed. It was extremely difficult to see where the coolant was coming from until the air filter box was removed. I leaned into the engine bay, placed my head where the air filter box was, looked to my left and saw a stream of coolant flowing from the bottom of the water pump's pulley. All the many many many hoses appear to be fine.
What else should be done now that this all apart?
Honestly, If you're planning to keep the car for the long haul. Change whatever hoses are easily accessible. You already have the coolant drained, and you have to bleed it. That's half the work right there.
I wouldn't go crazy and pull the supercharger off to check / replace that line, but the more you replace now, the less worry have of potential failure.
Take care,
George
Old 01-21-2011, 05:12 PM
Riski's Avatar
The should be a "sticky" with all the things about buying a Jaguar S Type R!
Search, and all your answers will be found, prob on the first page of the S Type section
Old 01-21-2011, 06:51 PM
1320racer's Avatar
Default Two water pumps in as many days!
My wife's 2002 Grand Cherokee V8 with 90K miles just began leaking coolant from the weep hole. I found this video clip that shows exactly how to handle the job.
http://www.blackhatboy.com/2004-jeep...at-replacement
I ordered the Jeep parts for $108 delivered: new water pump (not remanf), thermostat, upper and lower hoses. I also spent another $31 at Auto Zone for cleaners and coolant. The cleaners will also be used for my STR's water pump replacement.
I called three Jeep dealers to get an estimate and the low price was $991 + tax and shop fees and the high price was $1355 + tax and shop fees. So this goes to show you that all dealerships are good at marking up labor rates as well as parts.
Old 01-21-2011, 07:53 PM
ChrisSTR's Avatar
Stock water pump on the STR is a certifiable plastic piece of s***. You may want to find a better aftermarket replacement particurlarly if u live in hot climate.
Here's one http://eurotoysltd.com/catalog/produ...oducts_id=1322
1320racer (01-22-2011)
Old 01-21-2011, 08:19 PM
Michael Star's Avatar
reddrawf
A man after my own heart! I traded my 01 540/6 in for a STR.
Old 01-22-2011, 07:02 AM
1320racer's Avatar
Do you know the specific components that have been updated with the eurotoys water pump? They only state to "Replace that old design water pump (that is prone to failure) with this Updated Factory water pump from Jaguar." I will give them a call if you don't know off the top of your head.
I do plan to keep this buggy for a few more years, but even if not, I only purchase and install high quality parts since I want a reliable car for me as well as the next owner. It is a sense of pride and good karma...or is it good "car"ma.
Does anyone know if the original water pump in our STRs is the AC Delco unit? I have not noticed a label or stamping on it yet but will look again. I found the following water pump options at RockAuto:
-AIRTEX Part # AW4124 {#WP9354}
$59.99
-HYTEC Part # 114108
$63.73
-CARDONE SELECT Part # 5523149 {#PWP9354}; Includes Gasket
$68.79
-A 1 CARDONE Part # 58612 Reman. Includes Gasket
$73.79
-ACDELCO Part # 252800 {#89003363} PUMP KIT,WAT
$42.79
Old 01-22-2011, 07:26 AM
1320racer's Avatar
Howdy bimmer buddy
I had a 1997 BMW 540i 6speed from 25K-131K miles, then the car was stolen. Next, I had a 2000 BMW 540i 6speed from 41K-86K miles. Both drove beautifully but took a lot of money and work to keep on the road.
So far, my 2005 STR has been much cheaper to keep on the road. My STR is faster but does not handle as well as my 540is did. My BMWs were rock-solid at 155mph and I have not had my STR over 115mph because it just does not feel as safe at high speeds. I still love my STR though!
Old 01-22-2011, 10:01 AM
I agree, they are two different cars. The funny thing is that the str seems to have the more stiff suspension (plus the better setup for handling) but it seems to corner worse than the bimmer. I love the cheaper parts for the str too, fuel filter for the str is $10, whereas I think I spent $125 for the one for the 540.
I do miss the ability to row through the gears though...
Old 01-22-2011, 10:21 AM
JagV8's Avatar
Received 4,551 Likes on 3,958 Posts
The STR's handling should be excellent so could you have suspension that's either non-standard or not properly maintained?
Old 01-22-2011, 10:37 AM
vance580's Avatar
$59.99
$63.73
$68.79
$73.79
$42.79
According to what I've seen from what the OEM water pump looks like the stock water pump has a plastic impeller. The updated aftermarket ones I've seen have aluminum ones. I'm going to assume thats what the eurotoys ones have.
Old 01-22-2011, 08:04 PM
1320racer's Avatar
Thanks again this is good information to know. I will make sure the pump I purchase has the new and improved design. I received this message back from eurotoys...
Hello Bryan,
The new design is a 2-piece casting and incorporates a different impeller (made from a different material). Your 2005 would have had this on it already, it is redesigned when compared to the older cars.
Regards,
Mike
Eurotoys Ltd.
847-464-4000
Old 01-22-2011, 09:34 PM
Riski's Avatar
I still need to make my way over to the shop...its not far from me haha
Quick Reply: Looking to buy my first Jaguar
