Looking for diagnostic tool for Jaguar S Transmission Problem
Hello,
I have a 2002 s type 3.0 with 109,000. I have had problems getting it out of park, especially if I let it rock backwards on an incline.
I am planning to purchase the AutoExpert 200 with Latest software JLR V130 for diagnosis. Just wound, will the issues be solved if i purchase it?
Received 6,307 Likes
Sounds like you have the Ford 5R55N autobox. No separate module so no special OBD tool needed unless you're wanting to control its internals (solenoids/valves). Not normally needed.
The shifter (shift lever) is a known issue and there are threads here & TSB about it & fix. No OBD tool at all needed.
BrentGardner
28
04-26-2024 03:08 AM
hafren
08-30-2023 03:42 PM
Paradigm
06-15-2019 05:59 AM
