Looking For New Wheels
I'm really happy with the 18s. I had 19s on my last car and much prefer the 18s. I think the ride quality is better with the 18s and the wheels and tires themselves are cheaper. I did look around for some replacement 18s and they are almost impossible to find. So I am having the stock wheels powdercoated for $50 each, they will look great and it's cheap!
The 235/30R22 are 2" too big. That's dangerous. They're also too narrow.
245/35/20 are more than an inch too big. Why would you do that?
Wheels and tyres are a safety item. I would defend your right to put ypur life at risk but not to put lives of others at risk. Look after that issue first and go for bling next (if you must go for bling).
Factory tire size of 235/50/17 vs 245/35/20
The new size is .5 in diameter larger....And would "fit" and "work"
Anyone can check it here....
http://www.miata.net/garage/tirecalc.html
Now I think the point the OP must remember that other Jaguar models that have the same bolt pattern / and optional 20" wheels have different suspension components. The closest relative that has a 20" option is the XF.. Yes the XF is a re-engineered S Type, but one of the major changes from S to XF is totally different suspension components...
I think there is a reason that the largest upsize factory option for the S is 19". As with any upsize project, there is a sweet spot that needs to be attained. After you hit the sweet spot, the law of diminishing returns takes over...
For the OP and anyone else who wants to increase performance via upsized tires and wheels..Here is a great read that shows this.
http://www.caranddriver.com/features...sted-tech_dept
What is listed as the factory size for 17" wheels in the UK? I wonder if they have a different spec than the US?
yes i understand all the info you're posting up here, but 20/22 inch wheels would do fine in most situations here where i live(no snow, no severe weather), Ive been riding on low pro tires on different vehicles and traveled thousands of miles on them with no problems(of courses it is more risky i know).. and i acknowledge what you are referring too on the fit sizes..
my s-type is a V8 4.2 (i don't ever intend to use it for performance practice, which it will do its job wen i hit the gas) but it is not a "R"
& usually i keep wheels and tires for a year or less so safety issues never really been a problem..
*don't always go by the book or wat the "pro's say"** it/they is/are not always correct*
thank you anyhow..
thank you anyhow..
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Why would anyone play fast & loose with a safety issue? The size, thus rubbing, weight etc make it irrelevant which model of S-Type.
The book & pros are not always right but they're right a lot more often than the amateur who's out on a limb plus it's the amateur messing with safety items that usually causes the worst outcomes.
Jeff - don't know what they fitted on 17" but the 245s are about the same size as all other S-Type tyres except the 235s (which are larger by about 0.6", i.e. not much).
thank you anyhow..
thank you anyhow..
I've asked this a dozen times on a bunch of websites and I never get an answer.
What is the fascination with over sized wheels and the the rubber band like low profile tires? Is it like saying HEY I've got a bigger d*ck or something? You know, "if mys wheeels is dat big den you knows what else is"?
They usually look stupid and out of proportion with the rest of the cars styling unless it's been pimped-to-hell as well. The calipers end up looking a small set of you know what because there's now a foot of clearance between them and the rim. No one is really impressed by that ... You could put a set of huge calipers & rotors on there at the same time and at least it would be functional.
Now the spinning the wheel centers I do get. Because you never know when you're gonna need to grate some cheese at a stoplight ...
Apart from:
looking wrong
making the handling worse (reducing safety)
putting extra stress on suspension etc components (affecting safety?)
maybe rubbing, with risks of blow-outs (again, reducing safety)
needing more expensive tyres
probably having the wrong offsets (more reduced safety)
giving a harder ride
altering the speedo accuracy unless you're careful with profile etc
potentially leaving you uninsured (over here)
are there any other issues?
looking wrong
Apart from:
looking wrong
looking wrong
Not that "upsizing" can't be done..It just needs to be done right...
After putting the 18's on the Honda Coupe, I had to explain repeatedly to co-workers why it wasn't riding on 20's..
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Always the same answer... "It was done to sharpen handling, not look silly"... It did look cool with wheels that filled the wheel wells properly, but again, I did it to sharpen up the car... But even with being very careful with the specs, it still slowed the car down.. That is another point that people don't get...Just a little more unsprung weight kills the cars acceleration...Not that my Honda was a demon in a straight line..It was only a 4cyl.
Made me think back to when I was in HS and scratched my head when everyone put air shocks on the back of their car and big 'ol wheels sticking out in the back and teeny tiny donuts on the front...
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Or taking paint and spraying every single part of the car body color..
My point... There will always be a "culture" that destroys cars in an effort to "look cool". On the other hand, there are people across all cultures that "do it right" with craftsmanship and care... Those I appreciate...
