At a Loss
At a Loss
Well I thought I had all of this fixed but after installing a new climate control I found out it's still a no go.
recap:
I replaced the heater valve because it was only blowing super hot air. This fixed the ploblem it now blows regulated heat and cold A/C.
I took apart the climate control it had several burnt traced I tried to repair them. What happened is a little bit of air blew out of the very end vents, no air out of the middle vents, very little out of the defrost. It blew super strong hot or cold out of the rear passenger vents.
I thought the climate control must have a short I missed, so I bought another working climate control and hooked it up. It does the exact same thing.
I am at a loss!
It has to be something that controls the vents, But what?
Please help
I took the glove box out just now and don't see anything unhooked.
recap:
I am at a loss!
Please help
Ok while I have the glove box removed I started car and pressed the mode button on the climate control. I could see the blender motor rods moving with each press of the mode button. I couldn't however hear the blender doors opening and closing. This has me stummped.
Help
Ok I was look at the blender door motor kinda bhind the radio, I think it controls the floor vents cos air is comming out of it. The blender door motor to the right of the glove box is doing nothing when I press the mode button. I bet this is the one that controls the vents. How can I test it?
Ok I think that one is ok as well it is the recirc. motor.
Now on to the next one, is it behind the instrument cluster?
Help
Well I finally got the instrument cluster out. If anyone needs to know how just ask. The blender door motor I believe isn't working right. I played with the mode buttons while pushing the vents doors open. They were closed. I got them to open although I was able to get the motor to close the vents it would not reopen them.
I assume a gear is broken on the motor.
I went ahead and ordered a new motor, but I am dreading replacing it.. this is the hardest to get to motor of them all even with the cluster out..
PS if anyone needs a working dual climate control, I have a extra one...lol
Received 6,327 Likes
I am sending you both the same message. I think you are both working towards the same resolution and could be comparing notes. You both have a lot of help and may be on a solution soon I hope.
https://www.jaguarforums.com/forum/s...ad.php?t=50343
https://www.jaguarforums.com/forum/s...t=49227&page=5
I am also going to attach the little information I have that may or may not help. http://www.gusglikas.com/AutoRepairAC2000SType.htm You have a great resource on this forum and they are all willing to help.
I will to continue to follow your tests and solutions. Good Luck!
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
