Loss of power
Old 07-18-2012 | 12:42 AM
jagspeed's Avatar
Default Loss of power
This is strange to me. It seem like after my car is running for a long period of time, it will start bucking and eventually lose power. However, if I turn off the car before it completely lose power it will start and continue running fine again. check engine light is on, however its for CAT. Can a bad cat cause me to lower power or this is a bad coil problem. Thanks for any help
Old 07-18-2012 | 01:47 AM
JagV8's Avatar
Yes, but is that a result or a cause in your case?
Which codes?
Engine? Year? See:
Old 07-18-2012 | 08:36 AM
jagspeed's Avatar
the code is p0430 and 2000 Stype v8 4.0
Old 07-18-2012 | 09:15 AM
JagV8's Avatar
Not great news. Have a look at the fuel trims at idle and 2500rpm (in Park).
It's worth putting car info in your User CP.
Old 07-19-2012 | 12:11 AM
jagspeed's Avatar
my car info has been in CP for quite sometime unless its in the wrong place.What do you meant by not great news
Old 07-19-2012 | 02:32 AM
JagV8's Avatar
It helps if in signature in CP.
May just be a bad cat but they're fairly rare and often due to a fault elsewhere.
Old 07-19-2012 | 08:10 AM
1320racer's Avatar
I too believe it sounds as if one (or both) of your catalytic converters may be becoming clogged. My 2005 STR had CAT issues but there were no problems elsewhere. My case is not typical and most CAT failures are caused by an outside issue just as JagV8 mentioned.
The initial indicator of clogged CATs on my car was a small loss of power during full throttle and the restricted performance light would turn on sporadically for a few moments. Next, at full throttle, my car would "ping" and sounded like there was no oil in the engine. Next, at full throttle, I got random misfire codes and eventually CAT efficiency codes. Just before the CATs were changed the car barely ran and the CAT literally broke up inside and white flakes came out the exhaust pipe. At this point the max rpm of the engine was approximately 3500 rpm.
Old 07-19-2012 | 09:35 AM
abonano's Avatar
P0430 - Catalyst System Efficiency Below Threshold Bank 2 (Driver's Side)
More thank likely you have 1 or more bad or intermitient misfiring coils - this in turn would send unburnt fuel through the cat essentially burning it up.
First, check out the coils and it wouldn't hurt to check the plugs as well all around, but focus on bank 2 (driver's side) first.
Then when your 100% sure those coils are firing 100% of the time get that cat replaced. Hopefully the passenger side cat is salvagable.
I would also change both O2 sensors before and after the bank 2 cat when installing a replacement as well.
Old 07-26-2012 | 03:11 PM
jagspeed's Avatar
Ok the culprit is the cat. However, I was at the muffler shop and they suggest I put in a universal Cat. I was on board with it until I saw it was so different from the original in which they would place the O2 sensor in the pipe before the Cat whereby it sit in the original. Would this hamper the way th system works. I dont think so in theory but I could be wrong.
Old 07-26-2012 | 03:23 PM
guy's Avatar
guy
Out of interest, what mileage is on the car?
Old 07-26-2012 | 03:38 PM
jagspeed's Avatar
I just register 100K miles a week ago
Old 07-26-2012 | 06:07 PM
abonano's Avatar
I would stick with aftermarket CATs with OEM fit. You can find them on Ebay and such - about $200 - $250 each.
duecedriver
12-25-2015 12:47 PM
thedugger1
10-16-2015 11:06 PM
tiger4366
09-22-2015 10:20 PM
Johnken
09-15-2015 06:46 PM
Wolfy
09-11-2015 07:27 AM
Quick Reply: Loss of power
