Low coolant due to unidentified leak, and engine systems fault.
Hello. Purchased an 06 S type from Father-in-law and have the following issues: a leak in the coolant system(slow but steady) has occurred since my ac started acting weird a few weeks ago. The drivers side blows hot while the passenger side blows cold(briefly). I’ve been adding coolant to the system frequently and thought it was just due to the high temperatures in my area until I noticed a leak that would spray upwards(not in high volumes) and was accumulating on some of the pulleys. So Friday of last week, I was working delivering orders and the car started overheating and I had loss of power. Had it towed to my house and when I got it started again(after a jump), I got messages of engine system fault, cruise not available, and parking brake fault. I checked the reservoir tank and hoses and can’t figure out where the leak is coming from but looks like it’s close to the engine. It overheats on idle, drops to 500 rpm’s and has a weird whooshing sound in the engine. Appreciate any help you can suggest.
Welcome to the forum.
Lots to unpack in your message.
1) Do not drive the car until the overheating issue is corrected. You risk causing serious engine damage.
2) Get thee a coolant system pressure tester. It looks like a bicycle tire pump and connects to the neck of the coolant reservoir bottle. Manually pump up the cooling system to the pressure rating listed on the cap and then watch the gauge. After 15 minutes, decay should be minimal, maybe a needle width at most. If it drops faster than that, inspect everything looking for the leak(s). You mentioned coolant spraying near the pulleys, so hopefully it's not too hard to find. With the engine running at idle, pressure in the system is minimal, so you may not see much of a leak. The pressure tester stresses the system to find leaks you'd miss running at idle. Plus, it's much safer poking around without the belt and pulleys in motion
3) Don't skip steps 1 and 2.
4) Don't skip steps 1, 2, and 3.
5) Put away your jumper cables and charge that poor battery. You should never need a jump under normal conditions. Instead, figure out why you needed a jump and correct that issue. It could be as simple as the serpentine belt slick with coolant, causing the alternator pulley to slip.
6) Once you get the overheating and low battery issues resolved, you can troubleshoot your AC here:
https://www.jaguarforums.com/forum/s...ol-how-185002/
The following 3 users liked this post by kr98664:
What Karl said... AND, when time permits, please post the expected "intro" in the New Members forum, here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
BobbyD37 (08-01-2023)
The following 2 users liked this post by BobbyD37:
S-Type Owner (08-01-2023),
waxrola (08-07-2023)
https://www.jaguarforums.com/forum/s...3-0-v6-204901/
https://www.autozone.com/tools-and-e...t/loan-a-tools
I realize it's tempting to think you won't need to do a pressure test, but I highly recommend doing so. It will help you find leaks you won't find any other way.
The following 2 users liked this post by kr98664:
BobbyD37 (08-03-2023),
S-Type Owner (08-04-2023)
bad heater valve or burned up driver in the eatc and a bad scroll control valve
mpasiuk
24
03-14-2022 10:12 PM
