Low fuel pressure 2000 s v8
Hi guy's.
This is my first time on a forum of any kind. I like to start by saying that I am a weekend mec. My car has about 35,000 mi. I was running good until 1 day went to start it and started running bad and misfiring. .
Checked pressure and it was 40psi at idle.no codes.
Replaced fuel pump .fuel pump hose and fuel filter with no joy.got a mitchell account and looked it up but wont help since I got no codes
I wold apreciate if any one can give me any input its been a month taking rides from friends.thanks.
The fuel pressure will vary depending on how the car is driven but 40 psi at idle sounds good.
Do you have the JTIS? It will tell you what the fuel pressure should be. You have spent a good amount of money but I don't see where the pressure is low?
The JTIS is free on this forum and is the factory shop manual.
Received 2,263 Likes
please correct me if I'm wrong but I believethat if it was a bad coil I would have to have 3 or 4 out for it to run this bad.as I mentioned before fuel filter is new.The problem happened from running great and shutting it down for 20 minutes and re starting.My next move will be the cam.or the map ?? How can I bench test it ??
rsa760041
23
09-25-2015 01:33 PM
