LSD, Future is looking bright ;-)
Old 10-06-2015, 12:44 AM
Robinb's Avatar
Cambo, I thought I was done bothering you, but...
I read up (most of) the posts on that thread where, in March 2013, you fitted the Quaife. I saw this comment:
As it turns out, it was a very good idea to go for the bearing & seal kit. The pinion bearing was pretty badly scored and would probably have started making a lot of noise fairly soon.
Why then did you say "If I were to do it again, I'd leave the pinion alone".
....and did TL Jaguar supply all bearings, seals and kits for the job, or did you source all these items separately?
  #62
Old 10-06-2015, 01:39 AM
Received 4,457 Likes on 2,427 Posts
Because the guy that rebuilt the diff for me in Switzerland re-used the collapsible washer and over-tightened the pinion nut which destroyed the new pinion bearings after only 15'000kms and I had to get a complete diff from a wrecker in the US sent over and refit the Quaife centre to that one after the car was imported to Australia i.e. I've had to do it twice. 2nd time round I had the guy here just swap the center and leave the pinion alone.
TL supplied all the bearings and seals but they did not include a new collapsible washer & nut.
The following 3 users liked this post by Cambo:
Panthro (01-19-2016), paydase (03-01-2017), Robinb (10-06-2015)
  #63
Old 10-06-2015, 07:17 PM
Robinb's Avatar
Was that because without the collapsible washer to guide him, the guy tightend to a torque beyond even the new bearing spec?
Pinion bearing preload (used pinion bearings) ... 0.9 - 1.5 Nm (8 - 14 inch lbs.)
Pinion bearing preload (new pinion bearings)..... 1.8 - 3.3 Nm (16 - 29 inch lbs.)
Finally (I think) was there any significant change to the OEM ratio of 2.87:1 that required some reprogramming?
  #64
Old 10-06-2015, 07:34 PM
Yes it would seem that he did it "by feel" not following the spec.
Changing the diff center from open to LSD has not effect on the diff ratio. If you re-use your existing diff gears then no programming needed.
Robinb (10-06-2015)
  #65
Old 10-08-2015, 06:01 AM
crocodile62's Avatar
I will get the LSD from Quaife on monday and revert to you with pictures and descriptions
Panthro (10-18-2015)
  #66
Old 10-19-2015, 02:00 PM
Robinb's Avatar
Default No LSD for me
Cambo, I'm not in your class as a Jag tech, nor do I seem to have your drive and determination. I am going to abandon the LSD project for my STR, based on the following:
1.. The Quaife UK catalog shows the QFD3W as suitable for the 2003-2008 S-type, but the Quaife USA catalog does not.
2.. Quaife UK says I must deal with Quaife USA, leaving me to buy an item that does not exist.
3.. Alternatively, Quaife UK says "I would advise contacting our distributor XKR Transmissions who have experience in fitting our differentials to Jaguars who will be able to confirm this is the right differential.". So not even Quaife is sure!
4.. The local Quaife dealer here says "We can supply the differential unit, but have none of the tooling or information to install it in your Jaguar. Quaife doesn't list an ATB for your application. The part number you provided was for a 2006+ XK-R.".
... and after some clarification, the local Quaife dealer again:
"The differential would consist of the complete differential unit, except you would have to transfer the ring gear from the original and set the ring / pinion depth (special tools / equipment required).
The only other question is whether the European application / market vehicle has the same differential as the North American one that you have. If they are 100% the same and Quaife can confirm it for you, then the part should logically work for your car. Unfortunately, I cannot confirm that for you.".
This combination of expense, uncertainty and inability to instal and locally support the LSD is just too much. I mean, the cost could easily exceed 30% of the value of the car. It don't sound good and it don't sound hopeful.
Cambo, really appreciate your constant help and advice, and prompt answers to all my questions. Look forward to hearing how crocodile62 makes out.
  #67
Old 10-19-2015, 05:13 PM
Wow, that's kind of unbelievable... they sure know how to talk themselves out of business...
But they are the same diff...
You can buy it from one of the UK agents, Tom Lenthall or Racing Green.
They are pushing you back to a US distributor, but you don't have to deal with them, get a quote from one of the UK guys I mentioned.
In other words they've never done it before, so they don't know. Some of us do know, from first hand experience.
The 8" Gen2 diff is absolutely the same regardless of which market.
Here is the Quaife QDF3W fitted to the diff from my XJR.
It fits!
As I mentioned, the other option is to get a complete diff and driveshafts from a 4.0L S-Type V8, fit a generic Ford 8.8" 28-spline LSD center, but you will have to transfer the gears from your diff to it to keep the factory ratio.
But you would still need to find a competent workshop to do the work. Honestly this would be my greater concern. The parts all fit together, no doubt about that at all, but the quality of the installation makes or breaks the deal...
  #68
Old 01-07-2016, 02:29 PM
Tama505's Avatar
Hello!
I will be buying an LSD soon so if someone wants to join the order please let me know. I will go probably with Paramount Performance since they clearly state that the quaife fits STR 2003.
Jaguar S Type R Limited Slip Differential - Internal Diff Components for assembly to fit Jaguar S Type R
I will ask them to provide the seals and bearings as well even to the pinion just in case my diff is in a bad condition...
I will send an email to Tom as well and ask his prices as well. Probably there is not a big difference.
-Tama
  #69
Old 04-20-2016, 02:36 AM
Joburger's Avatar
Hi Tama. How's the LSD fitment going? You done it yet or is it still in the pipeline?
jagent
06-05-2022 02:18 PM
GGabriel
11-22-2018 03:53 AM
Delta66
10-04-2015 05:40 PM
Fletch44
09-28-2015 02:21 PM
Quick Reply: LSD, Future is looking bright ;-)
