LUG NUTS ?
LUG NUTS ?
Well this has been one long ordeal. Brake pads for my 06.
Finally got in a complete set of Akebono Euro pads " thanks h20boy " .
Guess I have to eat the rear set of EBC Redstuff “because they do not make a front set.
Figure that one out , why would they make the rear set but not the FRONT SET?[sm=badidea.gif]
MAKES NO SENSE TO ME. IT ABSOLUTELY HAS NO LOGIC WHAT SO EVER.
Trust me I have looked High and Low , they ain't out there.
Well made a comment a few post ago about Cheap Lug Nuts on the Jaguar.
So now I am finally making time to track down lug nuts and . . . .
All these option’s are killing me [sm=headbang.gif], questions like :Hex ¾ or 13/16 , thread ½ -7/16 – 12mm -14mm
Heck I don’t know what I need.
HELP PLEASE
As Always Thanks
HELP PLEASE
As Always Thanks
RE: LUG NUTS ?
Like me, I also ate the RedStuff pads, for nostalgic purposes later I suppose. I haven't even discarded them yet. They have maybe 50 miles on them too...sad.
Glad the Akebonos worked out for ya! Notice any decrease in brake dust yet?
About your lug nuts, not sure why so confused. Do you have to replace the old ones, and does it really matter what size OUTSIDE it is? I may be missing the bigger question here as to your dilemma.
RE: LUG NUTS ?
H2oBoy I have not installed the new pad's because . . . . . "ready for a long story?" :
Last month I was experiencing a fault message in my display.
It said Restricted Performance. I posted a message on this BB but no one seemed to have the
Answer. Which is very unusual because you guy’s are the best resource of informational out there.
Well I ask one of the guy’s in my service department “we work in a niche market that use’s medium hp engines”. So my tech say’s : Restricted Performance is either Air or Fuel. So he proceeds to investigate
“he will tackle anything” and tell’s me I need a new fuel filter. Which as anybody knows is located behind the front driver side tire. So he proceeds to jack my car up “with that cheap Jaguar jack ’ Then attempt’s to remove the tire , well the cheap Jaguar lug nut’s are two parts and the outer part strip’s off. Which in turn rounds the head off the main lug nut.
So I ask him of he could replace the fuel filter with out removing the tire and he say’s yes.
I tell him since I have new brakes on order “I was still trying to find the front EBC Redstuff” I will go ahead and replace the lug nuts – with solid ones , when I replace my brake pads.
I run my own business and have put the lug nuts on back order. But now the Texas weather is changing . . . . . Beautiful weekends , figured now is a good time to accomplish this task.
So i go on-line today and figured I could just Google "S-Type Lug Nuts" and ordre a new set.
Well I find a few web sitesand are given all these option's in sizes.
Heck I don't know what size I need . . . . . . which is why I posted this question.
Does any of that make sense [sm=smiley21.gif]?
RE: LUG NUTS ?
Cajun, apparently Red Stuff does make front sets. I found some in ebay, hope this helps: http://cgi.ebay.co.uk/JAGUAR-S-TYPE-...QQcmdZViewItem
RE: LUG NUTS ?
Thanks Guatejagbut will not work on a 2006. You are fixing to see a
listing for a rear set Redstuf "2006 S-type" . . MINE
Super_Nope still looking . . let me know if you find them. I found a sight that say's
they do , but they have like 6 size's to choose from.
Ran across this page but not sure which one's I need
http://www.morigen.com.tw/main.php?g2_itemId=38
SO ANY HELP WOULD BE MUCHAPPRECIATED
RE: LUG NUTS ?
bought a set of lug locks for 10$ from here that fit fine resolved my missing lug problem http://stores.ebay.com/Your-Pit-Stop
RE: LUG NUTS ?
I'm a recent, (2 mos.) owner of an '04 S.
Just picked-up new tires from Tire Rack and plan to have them installed by the local tire shop tomorrow and I'm reading this thread about stripping lugnuts!
Do I need to be concerned that the tire shop may strip my lugs when removing old tires?
Would it help to squirt a little "Liquid Wrench" on them tonight??
RE: LUG NUTS ?
FactoryJaguarTech
Yes the Fuel Filter did solve my"Restricted Performance Light " Issue. It was the weirdest thing.
I still have Factory Warranty but was dreading taking my Jaguar to the local dealer.
That whole lost of power really had me scratching my head.
Oh and I found a set of “SOLID” lug nuts for my Jaguar 12 x 1.5 $137.00 for 20 Ebay Item # 290209802923.
Kind of pricy but I have been procrastinating long enough, think I will bite the bullet.
RE: LUG NUTS ?
Most of the time lug nuts are stripped when people use there factory spare tire wrench to fix a flat
I"d chuck this wrench and but a 1/2 breaker bar with a 19 mm socket
Make sure the tire tech is using a 19 mm socket and if possible ask him to use a little antisieze on the wheel studs before reinstalling them
AndCajun Mojo
PM me if your interested in a set of NEW Jag lug nuts for a better price then that
AndCajun Mojo
RE: LUG NUTS ?
if you get a set of lug locks...then you have the other lugs that you remove from each tire as spare lugs plus you protect your rims from being stolen....they sell a set of 4 here http://stores.ebay.com/Your-Pit-Stop for $10 for the s type
