"The Lurch" Theory
#81
roger.grote (03-12-2014)
#82
#83
#84
Check your transmission oil cooler lines (there are two of them) at the crimped fittings where the metal piping transitions into the rubber hose section. Given the age of our cars now, a number of owners are seeing ATF weeps and leaks at these locations. Since you must remove the belly pan to inspect this area, most owners do not catch this issue until it has been ongoing for months or longer. You may be well short on ATF now as a result, and that could be causing your lurch issue....
#85
Received 2,266 Likes
Sounds very much like classic lurch. Whether a reflash will fix it permanently or not is uncertain. Somes car respond very well, other do not.
#86
#87
#88
webshark (08-30-2016)
Dickie_L_J_O
09-13-2015 07:44 AM
