Mafioso's thread!
So the castrol tranny flushed/filled 5000 miles later is great!
Did the Mina Gallery lower grille
Dyno'ed the car today here are the numbers
non corrected 317.8whp 341.9 lb/ tq 29.58 in-hg oat 92 degrees humidity 7% lambda 1.03
I chose non corrected numbers so it's easier to compare best pull was in 4th using a dynojet 5
Man that's hot (212 F.). I wished you had a low temperature (185 F.) thermostat at the time to see if this would have made a difference. I run a full exhaust mod, 1.5 pulley, and low temperature thermostat. The under hood temperature dropped noticeably, likely due to a free-er flowing exhaust: exiting exhaust gases face less restriction thus less friction= less heat and more complete combustion chamber scavenging= +power. The low temperature thermostat was the icing on the cake. Even on hot days the blowers charge coolers are only slightly warm to the touch.
I think I'd burn (scald?) my hand. Figured about the same temp. as the coolant passing through them.
You'll need an OBD tool. It's a non-generic OBD item but even an elm327 can read it if you know how to ask it. Some OBD software can be taught custom things, so if you have some non-free stuff have a look whether it's like that.
(IAT2 is on the STR, similar to IAT but after the air's boosted and cooled.)
here is a crappy video of the run, Man the blower sounds so evil not sure if its because of the accustics in the building or Im not used to it because the cabin is so quiet.
http://www.youtube.com/watch?v=9KpWPp-qbbQ
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
http://www.youtube.com/watch?v=tDzo4yRXwO0
Sorry for the delay in posting the results.
Made a bunch of pulls on the dyno and we broke the car I think.
full stock best pull was 349whp 376ft-lb
with intake elbow 362/382 ft-lb
I overtemped the cats on the 11th pull hp dropped 299 and the AFR was 8.9.
So I think some time this week its off the muffler shop to have the cats changed, x-pipe done. to cure the cat over temp.
Plus now after the day of playing on the dyno I did notice its running like my cats are cooked.
little bit of a rough idle and its running like its fell on its face.
![](http://i68.photobucket.com/albums/i27/lfrigoli/th_91102506.jpg)
![](http://i68.photobucket.com/albums/i27/lfrigoli/th_a66ed657.jpg)
ahhhh shiat, you didn't get the angled Hi flow Cats from Magnaflow like I mentioned to you before; take a look at the ones I have on my thread. These sit and fit a lot better than the ones you have. https://www.jaguarforums.com/forum/s...ad.php?t=43505
