Mafioso's thread!
So the castrol tranny flushed/filled 5000 miles later is great!
Did the Mina Gallery lower grille
Dyno'ed the car today here are the numbers
non corrected 317.8whp 341.9 lb/ tq 29.58 in-hg oat 92 degrees humidity 7% lambda 1.03
I chose non corrected numbers so it's easier to compare best pull was in 4th using a dynojet 5
"full stock best pull was 349whp 376ft-lb
with intake elbow 362/382 ft-lb"
If only 13whp came from the intake???
JG
I believe the first numbers were from a few months ago. When he was working on the intake he went to the dyno did a run with the stock intake then switched to the new intake then did a run back to back. I'm pretty sure he did it this way cause you are gonna get more accurate results as the parameters are all gonna be the same since the dynos were pretty much back to back. Hence the 362-349 is the 13whp gain he is talking about. The 318 to the 349 I'm sure are the parameters I'm speaking of as now the weather is alot cooler.
Vance is correct the 318 pull Was just to get a base line in the summer. Now it's fall 349 is a BONE stock baseline.
You can see how much power 30 degrees OAT stole from the car
I would love to get some pulls in the dead of winter when OAT is ~30's but with my current cat issue it's just not gonna happen.
I get it now, wow 30Hp is not bad from just good cold weather. I've noticed this too in both of my cars (Jag STR and BMW Z3 Turbo) cold weather is way better for the FI and even any NA engines, for sure. The air is far more dense, more O2 per square inch...
I was very lucky today, I thought I had a broken water hose under the SC, but as I took the engine's cover off, I started the engine and using a big screw driver moved some of the watercooler's hoses out of the way, so I could see better, then I placed a broom stick on the driver's seat and made it rest on the gas pedal and moved the seat just enough to make the engine rev @ 2000rpm, then I looked again and coolant was coming out from the end of the two small hoses that attach to the thermostat housing. So I cut them about 3/4" short and clamp them back and now, no more leaks...!!! YEAY!
My 3# Pulley is on its way, and today I changed my thermostat with the "low temp" one sold by EuroToys, now I really need to look into this CAT delete operation.
JG
JG
#28
I'm not sure how the widebands are going to feel about the deleted cats I'm not 100% sure the PCM will cope with the lack of a difference between the upstream and downstream O2's You can run the risk of throwing the car Into limp mode from the PCM freaking out and not finding the cats. You might be venturing into uncharted territories.
-Just food for thought
#30
To avoid this problem, you can buy O2 spacers, much like the spark plug non-foulers and install them with the second O2 sensors. They are cheap, and widely available. This is simply to fool the computer. By restricting the air flow through the sensors. You can even install more than one per sensor, if for some reason one can’t do the trick. I've seen people use as many as 3 in one install. By the way just to make it clear, this mod is only needed in the after CAT sensor (one on each side of course).
I did have one of these spacers in my Z3 turbo when I first did install the turbo. I took the Cat off and made my own strait 3" pipe with just mufflers at the end. No resonators or Cats, I was shooting for the max flow possible. But after I talked to my tuning guy NickG, he told me to just take off the second O2 out completely, he says the computer will ignore it, since there is no Cat in the system anymore... Now this might not be the case for the Jag's computer. But It could have been too, that it had to do with my custom made DME/ECU programming? I’m not sure, so I'll ask him anyways.
#32
JG
#33
it takes 1 each of these per side, so 2 each total. i got mine from radio shack
1.0uF 20% dipped tantalum capacitor
1.0 M Ohm 1/4 Watt 5% carbon film resistor (or 1/2W)
Unfortunately i did all that about 2 years ago so i can't remember exactly which wires were what. and the xjr is long gone so i can't check it.
But, if i remember correctly, the xjr's o2 sensor wires were 2 black, 1 gray, and 1 white. I used a voltmeter and some trial and error with an obd2 scanner on a laptop to check the readings.
#34
#35
The Cats do the real chemistry job here, in simple words they remove the unburned gas and most of the waist that does and doesn’t ignite in the engine. But to the computer the only way to tell so is by reading the slower smaller amount of air going, that’s ultimately slowed and restricted by the Cats when installed. The sensor doesn’t altered the Chemistry of the gases going through that’s done by the Cat itself, the sensor only feels the air (small, slow flow), and by that its hot or cold temperature, and because of this, it then knows the concentration of oxygen in the mixture. There for the computer knows the Cats are installed or missing.
#37
[COLOR=black][FONT=Verdana]
#38
So this is the real function of the O2 sensors, by reading the temperatures of the exhaust it knows how much O2 and fuel are being mixed...is simple (yes), but it gets the job done!
#40
If you believe otherwise, please provide evidence.
The O2 amount is fine for closed loop control.
In engines where exhaust gas temperatures are needed, temperature sensors are fitted (as well as O2 sensors).
