Mafioso's thread!
#41
As far as I've read, the O2 sensors do NOT measure temperature. They measure O2 (thus their name).
If you believe otherwise, please provide evidence.
The O2 amount is fine for closed loop control.
In engines where exhaust gas temperatures are needed, temperature sensors are fitted (as well as O2 sensors).
#43
#44
How deep into it do you want to get? google is your friend ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Briefly, there are 2 main types of O2s: the older (non-linear) type (used for all the O2s on the 1999 S-Type and downstreams on the redesigned 2002/3-on S-Type) and the linear (aka AFR aka wideband, sometimes confusingly called "universal") type (used as upstreams on the redesigned S-Type).
Both essentially react to the amount of O2 by producing a small voltage and even smaller current.
BTW, that they measure O2 is why misfires commonly result in extra fuel being added. It's to compensate for the extra O2. (If they measured temperature I can't see why a misfire would cause that.)
#46
#47
Marka
22
09-11-2016 12:09 AM
