Major steering problems Help
abonano,
Thank you for your reply. There is no cotter pin hole on either side. I have paid good money for parts and labor to replace both and I feel the play starting up again although the nuts have not back-ed off fully yet.
I am thinking now of selling the car, disclosing the problem to any potential buyer.
Since I like the style of the S-TYPE, does anyone know if the later years came with a permanent design fix on this? Or did they keep repeating the same mistake until the 2008? What a shame to have this achilles heel in a beautiful looking car.
I have this model and know about the ball joint nut coming lose. I check all 4 wheels regularly and I did use red locktight on mine. Alignment should be done and the tolerances cannot be out more than perfect. Accept no excuses about it. The company who does the alignment is not your problem. The guy doing it is your best friend or your worst wrench turner. Always look at the computer print out and if it is not right, do it again. If you put a bearing hub on, you should have done both sides (cheap insurance for later).
The following 2 users liked this post by S-Type Owner:
davidladewig (10-30-2020),
kr98664 (10-29-2020)
Dear Motorcarman,
Thank you for your expert guidance.
The X202 refers to must be a supercharged model?
I wish I had that improved assembly.
Thanks for the recall paperwork, I had no idea.
I will try to see if the dealer wants to change the ball joints as per recall, or since they are pretty new, just use red loctite on them? I think all they have is a white material washer of some kind, no cotter pins. This whole situation has me on edge, relying on red loctite for your life, cotter pin makes me feel a bit better. Drilling the studs myself could take forever. Selling the car may make me feel the best, don't know yet.
#28
David, having to have this perfect and checking so regularly is a big pain isn't it
#30
#31
Dear Motorcarman,
The X200 is the Model produced from 1999 to 2002 (MY 2000-2002)
The following 2 users liked this post by motorcarman:
S-Type Owner (10-30-2020)
#32
It is not a problem. I check them when I rotate tires. I have a silver paint touch on each joint. If the nut moves, iit will show up on my paint line between nut and thread. I use a mirror to see the line. Easy that way.
ThorssonJag
12-27-2008 04:04 AM
