Mass Air Flow sensor
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Just bought this car used an obd2 got a code of P0102 which is mass air flow replaced mass air flow getting same code with a reading of low input car will run but idles very rough and idles at 600rpms looked in the owners manuel for a possible fuse that I could check nothing in the book looked at the plug to see if there was any in line fuses couldn't see anything on that any suggestions please
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
The mechanic that I took it to said that the MAF has been the death of many Jaguars. I am really thinking that I bought a huge problem. The mechanic said that he is hearing a knock in the engine. Suggested taking it home taking the belt off and starting it up to eliminate any accessories causing the knock. Then go from there. Says the MAF could have caused the car to run hot. Very worried that this is going to turn into buying another engine
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
