Mass air meters... Anyone ever use a different one for the s type r?
Here's a thought that I don't know the answer to. Everyone knows that positive displacement blowers hate inlet restrictions. I believe this is partially why the inlet tube makes a good amount of power. But, ultimately we're limited by our 3" mass air meter.
Does anyone know anything about the mass air meter? Is it used in any other cars, ect? Perhaps if it is, maybe here are some hi-performance upgrades for the other cars that we can substitute on our cars.
Probably unlikely, but I thought I'd ask.
I don't think it would be feasible without some sort of ECU tuning. I think there is only so much you can do on a drive by wire system to get more air in and the intake tube would probably be about it. I think the best way to get more power would be if there were a known quality ECU tune for the car.
So long as the value the PCM sees from the sensor is right, it'll do its best with fuelling. You could read the sensor using a DVOM for various air flow rates and then change to a wider tube with a different sensor that creates the same values for the same mass of air. I doubt it's worth it, though!
Easier place to start is probably to fit pressure sensors before & after the MAF to see whether the current tube actually restricts the flow more than a tiny amount.
X_Type_South_Africa
12-09-2015 05:37 PM
stanjag
08-30-2015 10:35 AM
