Mesh Grille
#74
RE: Mesh Grille
ORIGINAL: KAZSAM
Don't forget the helmut, headboards can be very dangerous.[sm=headbang.gif]
BTW Uptown did you ever change to the mesh grill?
No, not yet. I plan on it before the end of the month for sure. I'm going to check with the dealer and see if it is just a matter of bolts to install. I looked at my current grille (I call it the weber grill...lol) and it is held on by bolts and seems to look simple enough. If that is the case... I may just buy the grille and do it myself to save a few $$. But I'm really excited about changing it- love the mesh! After that I would like to change the rims......
#75
RE: Mesh Grille
Uptown girl, the grill will probably be removed with 4 bolts. The bolts may be4 "TORX" screws. My '01 has torx screws.Finding a loose torx screwdriver is not an easy task. I had to buy a 110 pc Black and Decker tool set to get aTorx screw driver. As for rims, can you at least post pics of your car so that I can give you suggestions.
#76
RE: Mesh Grille
ORIGINAL: harounq21
#78
aholbro1
08-05-2021 06:02 AM
