Mina Gallery Intake
#41
#42
Ordered intake on 18th of Feb, it was in stock but have still not seen it. Spoke to Chris last week and he said it was dispatched but Has not arrived. Hope Mina is not getting to busy and can't handle the volume, perhaps Mina should up there postage and use UPS so we get a tracking number. Will call again today to find out where my intake may be. Had a list of Mina products to order over the next few months so bit of a test of customer service going on.
#43
#44
#45
The following 2 users liked this post by bfsgross:
goblue90 (03-05-2013),
Robert Page (03-05-2013)
#46
So quite the day tying to install the intake and my new HID bulbs without removing the bumper. I can say with full confidence that the Qwiketz elbow will take some modifications to work with the Mina intake. The stepped coupler that goes from the intake tube to the stock airbox will have to be replaced to one that is the same size on both ends. Luckily, the qwiketz elbow is the same diameter as the tubing on the Mina. Beyond that, the other rubber coupler that was supplied with the kit needs clamps; I am not sure why they did not come with clamps considering how much air this SOB will be sucking at red line. So hopefully I just saved someone a few hours and some disappointment. I will try for round 2 perhaps tomorrow or next week.
#47
Ps, after looking at cb Harley's post, it appears I have a cone shaped filter but he has a cylinder shaped filter. It also looks like he has hose clamps? One final note, the stock ram air setup does not fit snug into the square hole on the bottom part of the air damn blocking plate. Methinks I got a regular s type intake. Hmmmmmmm
#49
So installed Mina intake, must say it was not the easiest of jobs but that could be that I was attaching it to my Qwiketz elbow. I have a few points to make the biggest being that the cone filter I received is a bit too big for the compartment created by the heat shield and the hole it goes through is snug to say the least. I know it has to be snug to create a good seal but I had no skin left on my knuckles by the end of install. I must say that I did expect some codes to come up straight away as I did not think I was going to get a good seal on the Maf housing but no codes so all good. Kit could do with a bit more development but looks fine and no adverse effects so far but I have not had time to push he car yet.
#50
#51
#52
I talked to Chris at Mina quite a bit about this and I too had some issues at first with the hose clamps. I added the two you see in the photos for security and for vanity reasons. Those are actually T-Clamps from Spectre available at PebBoys for $5 bucks a piece...
I would give Chris a call and see what he thinks. I know both Seth and I had great experiences and a very easy install...
Sorry you ran into issues with your kit...
#53
I know some of the others got some "wrong parts" so you may have gotten the wrong filter and possibly the shield as well.
Was either cbharley or bfgross able to some how secure the ram air intake tube into the air damn square hole in the bottom area on the headlight side? if not, then I am unsure why there is a square hole there and am thinking the stock ram air setup should just be removed.
I should be able to use another coupler and clamps supplied originally with the Qwiketz kit.
#54
Been reading the post again and my XJR Mina does not have a hole for the stock Ram air supply tube! It does have a cut out on the lower edge near the headlight but this is just for clearance of wires and cables.Will have to call Chris and find out If I have correct parts or do you actually use the ram tube.
#55
Spoke to Mina and you do not retain the Ram air supply pipe from the OE air box. They say there is Enough air supplied from under the car and around the headlight. May see later if I can fit some flexible tubing from the front lower grill to direct more air to that area a bit like some of the K&N kits that I have used in the past. May look into this when the weather gets warmer. Took some photo's of the set up in the XJR and will post tomorrow.
#56
Robert Page (03-13-2013)
#57
I guess there are some now that do have a OBDII reader so they can check their intake temps. That will show if there is enough cold air coming in.
Ideally some checks what the temp does at idle, cruising at 30 and 60 mph and also some checks doing a couple of power runs to see how the temp behaves. (Please also note the outside temp obviously)
Bad Cattitude (03-12-2013)
#58
So drove Ronnie today and crap Engine check light has come on! Have only driven car prob 20 miles in the last week and have had no issues. The only thing that I have played around with is fitting he Mina, car is driving fine and no restricted performance. On my way to parts store to buy an OBD reader so I can find out if code is Mina related or something else.
#59
#60
