Misfire
If you have the 3.0 V6 and have not replaced your two factory Intake Manifold Tuner Valve O-rings (IMT O-rings for short), that could be your culprit. The factory IMT O-rings (yellow in color) were poorly designed and tend to start leaking as the years go by, usually throwing misfire codes. The improved IMT O-rings (green in color) are much thicker and sturdier and usually solve the misfire problem....
I replaced mine in January 2010. Zero misfires since. The part number is C2S40669. You'll need two. Be sure the new ones are indeed green....
Norri
19
09-28-2015 08:43 AM
