Misfire
Scholzjag (10-15-2017)
Received 2,632 Likes
+1 on testing or replacing the coil units.
Quite often engine oil finds its way into the spark plug wells and causes the coil units to short. When you remove the coils, check to see if there is any engine oil present. If so, the cam cover gasket and spark plug seals will need to be replaced.
