Mission accomplished Thanx
Received 9,010 Likes
I have to take a step back and say I did end up having to repair the rccm (remote climate control module). After taking the unit apart it's easy to see what happens when the dccv fails. The copper traces on the pc board are so thin it doesn't take much current draw to toast those foills. I replaced the burn't foil with 24 gauge shielded wire and tested all the output transistors.
I am happy to report that the unit works fine and there is cold air aplenty.
Thanks again to the forum for all the tips leading to this fix.
In particular make sure the hose attached to the bottom of the coolant overflow tank is properly engaged and locked. It is possible for it to be in place, look engaged and actually hold water but not be fully seated. It then can eventually come loose and you can pump out all your coolant in seconds. With no coolant in the system, your coolant temperature sensor would not be immersed and never show an overheating indication. If you then miss or ignore the low coolant message your engine is toast in about 5 minutes of highway driving!
