more front wheel bearing questions
Hi guys. I need to change my front wheel bearings on my 02, and I'm a little confused by some of the terminology in some posts I've read. I *think* when people say they've replaced the front wheel bearing, they mean they've swapped out the entire hub/bearing assembly? Are the bearings a serviceable item (like older cars like my TR6)?, or is the only option a hub swap? More confusing is guys mentioning prices of around $40, but the hubs I've found on ebay are around $300? I understand I'm up for a bit of a battle removing that hub, but once out, can I swap any bearings, or do I chuck it out? I can't seem to find any reference to the procedure in my manual either.
cheers
Ian
cheers
Ian
The following 2 users liked this post by JagV8:
ian.fox (03-21-2020),
Jumpin' Jag Flash (04-28-2020)
The following 3 users liked this post by Grant Francis:
Grant Francis (03-21-2020)
Here is a good read:
https://www.jaguarforums.com/forum/s...removal-53275/
Grant, I did ours in less than 1 beer in my bathrobe, haha
The following 2 users liked this post by joycesjag:
I recently did the serpentine belt on the X Type, STUPID layout, and that went 10 beers.
cheers
Ian
cheers
Ian
For the rear, you cant actually press out the bearings and press in new ones
So. I picked up this unit from ebay, and it seems to be in good nick. I'll just need to transfer my brake baking plate. Problem is, I now discover it's for a diesel car? Does it make a difference? It seems strange they would change a component like this.
The part number is 2W93-3K186-E.
03Xtype
10-19-2015 06:25 PM
