More problems... Low coolant dummy light
if it's the hose under the bottom of the supercharger, the coolant will be on the backside of the engine and on the belly pan.
Last night I pressure tested the car and I found a pinhole within minutes. The hole is on the S shaped line that wraps around the coolant expansion tank and then goes near the snout of the blower. I'm not sure but I think it attaches to the thermostat or something else toward the middle of the engine, toward the top. It should be easy to replace.
The part was AJ811771. I did a quick glance over the net but ended up ordering from the local dealer. The cost out the door was $86. Fortunately, it looks like an easy repair.
By the way, I also used the harbor freight radiator pressure testing kit. It comes with tons of differnt caps to fit just about all applications. It cost $100 but I had a 20% off coupon.
As I mentioned earlier, I also experienced a coolant leak early this week. Upon further inspection it turns out it was the hose that goes from the T-Stat to the water pump as shown by the hose connection diagram below
![](https://www.jaguarforums.com/forum/members/dimension247-49654-albums-t-stat-water-pump-hose-2984-picture-pipe-connections-9051.jpg)
fig 1
These are the pictures of the actual hose that I removed.
![](https://www.jaguarforums.com/forum/members/dimension247-49654-albums-t-stat-water-pump-hose-2984-picture-pinhole-9052.jpg)
fig 2. Pinhole
If you look closely in fig 2 above you'll notice the over-sized pinhole that was result of the imminent rupture.
![](https://www.jaguarforums.com/forum/members/dimension247-49654-albums-t-stat-water-pump-hose-2984-picture-micro-cracks-9053.jpg)
fig 3. Micro cracks inside
![](https://www.jaguarforums.com/forum/members/dimension247-49654-albums-t-stat-water-pump-hose-2984-picture-weakened-reinforcement-9055.jpg)
fig 4. Weakened reinforcement
As seen in fig 3 the hose had a lot of micro cracks inside the tube to a point that it had weakened the hose reinforcement as a result it had become very soft fig 4.
About a year ago tbird6 posted some research that had been done by Gates, a belts hose and hydrolic equipment manufacturer.
Article
To summarize, they basically attributed the hose failure to a phenomenon known as electrochemical degradation. It occurs because the hose, liquid coolant (ethylene glycol antifreeze and water), and the engine/radiator fittings form a galvanic cell or "battery". This chemical reaction causes micro cracks in the hose tube (see fig 3), allowing the coolant to attack and weaken the hose reinforcement. Accelerated by high-heat and flexing, the hose can develop a pinhole leak or rupture under normal pressure.
This is exactly what happened to the hose that I removed and possibly the cause for most hose that we're experiencing.
BTW this hose was $25 from the dealer and didnt take long to replace.
fig 1
fig 2. Pinhole
Article
mine was hose #3 in the diagram above. Due to the shape of it, it was expensive. When I asked the dealer approximately how long they'd bill me to replace it, they said 1 hour. Good thing I did it because it was an easy repair that was done in the dark with a flashlight in less than 10 minutes. The car is back up and running!
rsa760041
23
09-25-2015 01:33 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
