mpg
#41
#43
Sounds like its in need of a tune-up? Plugs, fuel filter, throttle body service, mass sensor cleaned! Air filter dirty/plugged? Sometimes it's the little things that are looked over far to often. I am an over maintainer of all my vehicles. Always have been always will be. But the throttle body service is a big help. Along with a good fuel injector bottle to put in the tank every 10k to 15k miles. Also my latest thing I have been doing to vehicles is cleaning the mass air sensor with mass cleaner. You will be amazed at a little oil or dirt or even dust that sticks on the resistor that once cleaned off frees up a little power, along with throttle respone. But most importantly mpg!
These are computers. Not lumps of metal.
#48
Actually, your claim that this test is impossible, even if changing wheels on the one car as you propose, is also wrong - but we credit your arguments for a solution that should have been obvious to us from the start - repeat the test over the same stretch of motorway, using the same "no traffic" time of day (actually, night into day), same cars, with the same drivers, same fuel etc etc etc but with each car now fitted with the wheels and tyres of its twin.
We have exchanged wheels already in preparation. We will drive off early tomorrow morning - once again, both vehicles will be in convoy but never slip-streaming, and I will post our results when we return.
We do not expect that, despite your objections, the 10% variance in fuel consumption is substantially due to anything other than the increased width and rolling resistance of wider tyres. Remember, we are not rubbishing fat tyres - and you would hardly call 245/40R18s "skinny" - nor are we chasing fuel economy per se - we simply seek to know what is the impact of "wider than the widest factory option".
Perhaps it will amount to nowt (whatever that means LOL). Tomorrow should tell all.
Cheers.
#49
You might get the results you expect and you might ineed find the fuel usage difference is due to tire width, but I have seen identical vehicles, purchased the same time, serviced the same, carrying identical kit and have seen more than a 10% difference in fuel usage between vehicles, we used to use 3 identical range rovers to patrol a stretch of the m6 motorway and every driver noticed a difference in fuel usage between them but 1 in particular was much worse than the others. Due to the kit we carried and the light bar on the roof we never got anywhere near the official figures and land rover just dismissed it saying all vehicles, even identical ones, use different amounts of fuel.
It wasn't just the range rovers, most of us noticed a difference in fuel usage between the same vehicles of the same type and age.
#51
#53
Yes ... Sorry for my delay in posting results ... my locum work intervened unexpectedly. I hope that the attached results translate successfully, because, while I have included some details of test methods, I have not had time to detail a comprehensive analysis. None are intended to convey typical or reproducible fuel consumptions - simply, that the comparative relationship is as valid as possible for our two VIN N8xxxx cars traveling at steady 110Km/h (70mph) on a major open motorway.
As can be seen in the results, the 9.8% variance from the first test was reversed to an opposite 6.9% in the second test, along with the transposition of wheels and tyres. The difference in increased fuel consumption was reversed - but by a significantly reduced margin.
As was expected, the greater adhesive factor and friction co-efficient arising from the road contact of the wider tyres is a significant factor in fuel consumption. However, even though wider wheels & tyres accounted for about 8% change in fuel consumption - as was predicted by at least one correspondent (police666), other factors accounted for about 2% change in fuel consumption.
These results have not been construed to achieve any predetermined goal. A range of contributors have pointed to sources from Newton, the continually evolving Laws of Physics, to the field of bicycle racing using very thin, hard tyres to reduce rolling effort and wind resistance.
Make of the results what you will - we do not see any Jaguar owners (particularly STRs) racing off to buy skinny tyres - a dangerous and foolhardy move indeed - but our findings do put some previously untested numbers against fitting wheels significantly wider than those which Jaguar provided as the vehicle manufacturer.
We look forward to your feedback and are happy to try to answer any questions.
Cheers.
Cheers.
#55
