Muffler Delete
Muffler Delete
So, I am curious if anyone's ever done it? It is a very common thing in the BMW world (my M5 has it) and it sounds great. Growls when you step on it and a nice melody when I cruise, without being obnoxious.
Basically, chop off the two rear mufflers, run a straight pipe and weld some tips.
Any sound clips?
When I searched I came up with STR's (no V6's) and most of them had magnaflows.
Thanks..
Any sound clips?
Thanks..
Bacardi 151 (10-19-2011)
I did it to mine. Drone is low in cabin at freeway speeds (the wind noise is louder at 80mph). Car is still pretty quiet even without the rear mufflers. When I took it to the Texas Mile earlier this year, there were a few people that wanted to know if it still had the stock exhaust on it because it was so quiet.
Nada, just no rear boxes.
<object style="height: 390px; width: 640px"><param name="movie" value="https://www.youtube.com/v/picasacid?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="https://www.youtube.com/v/picasacid?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></object>
O.k. just to clarify the OP has a 3.0.
So on that note I can chim in and say you will not like the sound. I did it when I first baught the car looking for more note. WOT it sounds GREAT, at itel it sounds GREAT. Everything else sounds like ***. I was embarresed to drive it normal, and it is WAY too slow to go WOT every time. If you like the Honda Civic Coffee can exhaust with a Ironing Board bolted on the truck lid thing then you might like it.
Edit: BTW, you can test this in less then 10 min. Just remove the rear section and go for a ride. The extra pipe and tips wont change the DB or sound much at all.
Wait a minute! Shultz brings up a very important point. bmwlover has a 3.0 V6, not a good motor when messing around with exhaust...very difficult to quiet down. I had an 02 X-Type 3.0. Modded the exhaust and regretted it. Bolted on lower restrictive exhaust manifolds from a 1989 Ford Taurus, placed a single dual inlet/single outlet cat from a late model Dodge truck V8 under the passenger floorboard. The stock cats cook these engines because they are directly bolted to the side of the block. I mistakenly used one duel inlet/single outlet cat from a Dodge V8. She flowed but the interior cabin noise/drone was very annoying and impossible to quiet down. If you must; use two inexpensive aftermarket "regular" cats, place one after the other (can't place side by side) under the passenger floorboard (this was performed by X owners). Don't use Magnaflow hi-flow cats, you'll lose too much back pressure. You may try this arrangement using the stock mufflers, then try aftermarket mufflers...My experience pal.
baskervillema
10-01-2015 06:43 PM
