Multifunction headlamp/blinker lever.
A while back I had this odd problem where using the turn signal lever was switching the head lamps between high/low beam even tough I wasn't pushing it forwards. It had become super sensitive. I just ignored it and that went away eventually.
Well last week another symptom developed. The RH blinker would not turn off unless you put the left one on. So I repeatedly move the lever up and down about 30 times and now it's been gone for almost a week now.
Anyone else have similar issues. My car has about 40K miles so it's hard to believe it's worn out.
Do you need a new blinker bulb? On some cars (don't know if an S-Type is one of them) a turn signal refusing to blink is often a signal of a bulb failure either in front or back.
Jaguar - it's not an automobile, it's a Motorcar
Perhaps but the high/low beam thing went away and that was about two years ago and now this stuck on RH blinker issue cleared up rather easily.
If it comes back then yes.
I just wondered if anyone else had experienced this.
I will fix no expensive issue before it's time! LOL
