multiple codes being thrown please help
Hello friends!
I have a 2002 S-type 4.0 which just had both PCM relays changed at the dealership.
I drove the car for one day and the check engine light came on. I hooked up the code reader and got the following codes:
p0302 - misfire cylinder 2... ok
p0300 - multiple misfire... ok
c1805 - something to do with abs?
u1262 - no clue
c1963 - stability control inhibit warning... whatever that means
The car shudders at idle and under heavy acceleration/load. If the codes were just for misfires I would simply change coils plugs etc, but the fact that there are these other mysterious codes as well I wonder if the problem is a sensor somewhere? Something obvious I'm missing perhaps?
Any help is greatly appreciated.
u1262 - no clue
Your shuddering at idle and on the highway is due to the P0302 code (passenger side - second coil from front of engine) you should make sure the connector to the coil is on and if so - replace the coil. Any oil on the coil boot will require the cam cover gasket and associated O-Rings to be changed. Once you fix the P0302 the P0300 should go away as well (unless there are other coils misfiring intermittently) As far as the other codes - tackle them after rectifying the coil misfiring issue
philwarner
25
06-26-2021 05:43 AM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Andrew Fanshawe
09-14-2015 07:40 PM
1964Daimler
09-09-2015 11:20 AM
