My Aspen Green STR...
#81
So I updated the STR's exhaust a few months ago... new 2.5" stainless from the header/exhaust manifold back. Deleted the cats altogether this time around (from high flows before), and replaced them with these catalytic-in-appearance, stainless 2.5" resonators from vibrant.
From there, more 2.5" stainless piping, with an H-pipe as you see there, followed by the factory resonator box, and then mina-axle-back exhaust...
![](http://www.pictrace.com/b/HDtx/exhaust_01.jpg)
![](http://www.pictrace.com/b/NiSHz/exhaust_02.jpg)
![](http://www.pictrace.com/b/mgZdOw0/exhaust_03.jpg)
Video clip for the sound coming soon...
And... the audio clip..
Panthro (05-12-2015)
GT42R (11-17-2014)
#84
#85
The following 2 users liked this post by rasputin:
GT42R (11-14-2014),
JagSTR2004 (11-15-2014)
#86
#90
Hey sorry, the old cats I think were finished, so i opted to just toss them out.
The secondary o2's are not threaded into the exhaust, just put a custom cap on them, and have them zip-tied out of the way. the o2 bungs in the exhaust pipe are plugged off. no CEL's or performance issues. The secondary o2's are just there to verify cat converter operation.
Was hoping my eurocharged ECU tune would have disabled the secondaries all together... might ask them to do so if possible at the next eurocharged open house...
#91
#93
#94
#95
#96
No CEL's with the o2's setup this way...
In my past experience of trying to eliminate p0420-cat-efficiency codes due to high-flow-cats/cat-deletes, the 'sparkplug defouler' trick at the secondary o2 would work well. A reduction of exhaust flow directly over the sensor was enough to fool that particular emissions-only monitor...
Recently, I've found that merely having it plugged in and reading free-air, is enough to avoid throwing any p0420 style cat efficency codes, or any other code, so for now, that's how I've left it, and it's been fine for the past 5 months. I would consider threading them back in along with a defouler/spacer, to have it looking proper undearneath, come inspection time.
It's not uncommon in aftermarket tunes/programmers, to have the option to disable the secondary o2's altogether. Will not effect engine operation in any way, and will test perfectly fine on the latest obd2-based emissions testing procedures... I'm fairly certain eurocharged can disable my secondary o2's if I so specify the next tune around...
ZenFly (11-05-2015)
#97
#98
Hi there your car looks fab as I have said in the past.I have as type jag 2007 XS model.
I have recently bought Factory Xenon's to try and fit to my car,but am having trouble getting the lighting circuit for it.Could I ask if you have it in your car handbook and if so could you possibly scan it and send it to me.Ill let you have my email if you have and would.I would be eternally grateful if you have and would for me.Many thanks
Roger
Roger
#99
See https://www.jaguarforums.com/forum/s...lights-131917/
It's too hard to do... you'll be driving illegally unless done fully... expect MoT fail unless it is (but if you find a way to get a wrong pass then you'll still be illegal which affects insurance).
It seems a good idea, it's the reality that's a nightmare.
roger.grote (11-28-2014)
The following 2 users liked this post by Michael Star:
GT42R (12-01-2014),
roger.grote (12-02-2014)
