my first set of error codes
my 03 str welcomed me with restricted performance message yellow and red lights were on as well as the check engine light, after i washed it.
p1111
p1254
got them erased at autozone and they did not come back
trunk floor got wet for some reason.
what is your opinion?
RE: my first set of error codes
P1254 EMS
OBD II
Throttle “limp home” spring
malfunction
Idle engine
Switch OFF ignition for 10
seconds
Start engine and repeat
2 R ECM Default:
– Vehicle speed limited
– Throttle opening limited to
30%
– Speed control inhibited
— Throttle limp home spring failureP111 is just "system ready"
Guest
Posts: n/a
I would never wash my engine
not worth the risk
not worth the risk
ORIGINAL: tomciob
not that particular time
but sometimes i spray the engine compartment as well and nothing happens those times.
is there anything i can check? filter is fine, nothing is loose on the intake side.
Yesterday it rained pretty hard while i was driving, today nice and sunny so i washed JUST the wheels.
2 hours after i start the car and get restricted performance right away, drove it anyway with 2 restarts and the message went away and car started to drive fine, however check engine light remained on, even though the car drove fine. Went to autozone and it showed the same set of error codes p1111 and p1254.
Since the floor of my trunk is slightly wet it must be water related, but what can i check for water intrusion?
