My Jaguar S type gearshift stuck in P position and will not engage in to D
I was parked and my automatic gear shifter was stuck in park. it won't come out of (p). But It did eventually came out. I drove the car and stopped putting back in park, pressed brake and went to put back in drive and it was ok. But It did get stuck other times. Can someone please help me
Yes, please, more specifics are needed.
What year is your car?
Early models ('99-'02) have a 5 speed transmission. 4 is the number displayed at the bottom left corner (D=5) of the J-gate bezel. This model has trouble with the transmission sticking in P if parked on an incline without the parking brake set.
Late models ('03+) have the 6 speed, with 5 displayed at the bottom left corner. This model has trouble with the bolts working loose that attach the shift cable to the transmission housing, but I don't think that would lock the shift lever.
Also, when the shifter is stuck in P, how far can you move it? If you can only move it about halfway to park but seems to hit a solid stop, that's the interlock within the J-gate not releasing for reasons unknown. If the shifter feels springy, as opposed to hitting a solid stop, that's a different problem.
http://jagrepair.com/images/TSB/TSB2...%20Release.pdf
http://jagrepair.com/images/TSB/TSB2...ck%20Lever.pdf
http://jagrepair.com/images/TSB/TSB2...h%20J-Gate.pdf
Some refer to the 5R55N and others to the 6HP26/28.
RayR
09-26-2022 04:43 PM
Digital Will
03-06-2020 03:50 PM
hunterpedigo
06-21-2017 08:59 PM
hunterpedigo
10-29-2015 05:31 PM
