My shifter solenoid has gone bad. I need an affordable solution.
Old 02-04-2013 | 01:19 PM
Candy's Kitty's Avatar
Default My shifter solenoid has gone bad. I need an affordable solution.
I'm using a flat head to get the car out of gear for the moment. I'm wondering if I can get the solenoid out of the assembly and replace it without replacing the entire assembly.
I believe the check engine lite is on as a result of the solenoid failure. Can I remove it all together and replace it with a resistor or maybe even just secure the piston in the unlocked position?
I have a 2003 S-type
Old 02-04-2013 | 04:08 PM
abonano's Avatar
I've heard of hot wiring this solenoid - but I would look into getting a replacement assembly from a boneyard.
Old 02-04-2013 | 05:04 PM
cbharley10's Avatar
Default Replacement Shifter
Hey there!
Check your previous post (the one with all the pictures) I posted a couple of options for you that are both less than $100 with shipping!
Cheers!
Candy's Kitty (02-05-2013)
adam699
10-13-2015 06:53 PM
n2audio
17
10-09-2015 11:53 PM
Johnken
10-02-2015 11:12 AM
Johnken
10-01-2015 06:07 PM
Quick Reply: My shifter solenoid has gone bad. I need an affordable solution.
