Navigation problem need help
Guest
Posts: n/a
Have a 2000 S-type. My nav was working fine. Playing around with the diagnostic screen I depress the reboot nav system option.
Message was " wrong reboot disk" the the system shut down. Can not get it to turn on again.
Only thing I can do is get into the diagnostic screen which tells me error code NG 50, 52.
I need help. Was I looked out of the system? Do I need a code to get back in? Do I need to cry!!!!
Thanks, Frank
Thanks, Frank
You will have to take it to the dealers and they consult their
TSB's the options will include replacing the DVD unit!
Don't have a heart attack as the actual solution (worked for
me) is that they put the firmware DVD in and leave the
ignition switched on for about 20 - 30 minutes, this allows
the system to reboot itself and burst into life.
Seems a good idea to leave these setup buttons alone
unless / until we have supporting documentation regarding
their actual usage !
________
Grape ape pictures
________
Grape ape pictures
Guest
Posts: n/a
Mine is an 05
Ah, ok....I get it now...
Sounds like your unit took a permanent vacation?
What did he say the problem was than?
________
Weed Vaporizer
________
Weed Vaporizer
