NEED HELP
Hi
Just check the s-type drc and that code dont exist
you would be better finding some with Jaguar IDS/SDD to get accurate codes and to give you accurate causes
even buying a Icarsoft LR V3, which is the best out there for our cars, apart from Jaguar IDS/SDD, but icarsoft lr v3 will talk to most of the modules on the car
unlike cheaps ones which only talk to engine ecu and give generic useless codes
also if your in the AA get them out and get them plug in for free
cheers
Joe
cheers
Joe
kr98664 (09-08-2022)
Are you seeing any symptoms with this code? Check engine light? Rough idle? Restricted performance message?
Or does this one simply show up any time you run a scan for codes?
If no other associated faults or indications, it might a case of your scanner not playing nicely with your car. In other words, it could be a nuisance message that doesn’t really mean anything.
Please let's treat it as we would any other code - there for a reason (possibly more than one reason).
daro31
02-17-2017 05:10 AM
