Need help with codes
Any code starting P0 is generic so you can look them up all over the net.
P1s are maker-specific so specify jaguar as well as the code and google etc will find them.
With so many P30x codes you almost for sure have an air leak and need to fix is so you don't trash your cats. You may wish to leave the others for now.
There are old threads about the codes and misfires especially so do some reading![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
If you don't have jtis, get it.
Or find a good tech and he'll fix the lot I guess.
The JTIS program jagV8 is referring to, is a great DIY mechanic source for repairs, even contains a full listing of codes and possible causes. If you search the forum for JTIS, there is a couple different locations for downloading the proper files necessary to burn your very own disc...if you have a CD writer on your computer/laptop.
If not, ebay sources have them for under $10, and is well worth the investment.
good luck.
good luck.
philwarner
25
06-26-2021 05:43 AM
