Need Help...Jaguar S-type won't shut off
I knocked my entire side mirror off my 2003 Jaguar S type V6. A few days later the alarm started going off randomly all night and day. Then I tried to turn the car off and it wouldn't shut completely off even with the key out of the ignition. Then two days after, the car wouldn't start at all but the lights were still on in the dash. I purchased a new battery and the car started up fine. 20 minutes later I tried starting it up again and it wouldn't start. When I tried removing the key, it was stuck and it wouldn't turn all the way off. Finally got the key out after several tries. Unhooked the battery and hooked it up again and the car started, but when I tried turning it off the engine was still running. So I drove a bit and parked it...now it's not starting again.
Error Codes on Dash
DSC not available
ABS Fault
Gearbox Fault
and just recently CAT System fault
Error Codes on Dash
DSC not available
ABS Fault
Gearbox Fault
Received 2,263 Likes
Received 6,310 Likes
It sounds to me like it may be showing signs of a switch fault.
Search the forum for boot/trunk leaks there is a lot of info, but yes, your first move will be to dry it out, some people make holes in the floor under the spare, there are holes in the metal just covered with the lining that you can punch through.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
abonano
25
09-25-2015 10:43 AM
