Need help which is positive or negative for Subwoofer wires.
Finally this afternoon I took apart my rear deck cover, and my car is a complete mess. Hopefully tomorrow I should be getting my two 8" 4 Ohms, "e3.8 Elemental Design subs" which will hook up to my factory Amp (should be an easy plug and play procedure), if its not that great sounding then I'll hook it up to another Alpine Amp and use and Inline converter. The previous owner already had made two 8" cutouts from inside the trunk where the original 6.5" cutouts were. Cool thing is he dynomatted the whole area under the rear deck. Unfortunately he also cut some wires up that hook up to the Subs on both Driver and Passenger sides as a gift to me
. Can someone who has done the rear sub swap job tell me which wires are positive and negative for the Drivers side and Passenger side; so that I will be able to hook it up to my new 8" subs, please?
If you can just fill in the question marks that'll be the easiest way.
Thanks.
Driver side:
1) Yellow/Black stripped wire= ?
2)White/Black stripped wire= ?
Passenger side:
1)Green wire= ?
2) White/green wire= ?
I have taken Jason's pics to illustrate how the wires are connected originally to the 2 6.5" subs in the rear deck.
![](https://www.jaguarforums.com/forum/attachment.php?attachmentid=9165&d=1301705034)
![](https://www.jaguarforums.com/forum/attachment.php?attachmentid=9167&d=1301705435)
This is how my rear inside looks like gutted out........
![](https://www.jaguarforums.com/forum/attachment.php?attachmentid=9168&d=1301706014)
8" cutouts from the inside of the trunk. New subs will be screwed in from the inside of the trunk.
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
Thanks.
Driver side:
Passenger side:
1)Green wire= ?
LOLz.... nevermind I found out, it was right under my nose. Had just to look at the diagram to to figure out the pos and neg wires..... ![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Driver side:
1) Yellow/Black stripped wire= -
2)White/Black stripped wire= +
Passenger side:
1)Green wire= -
2) White/green wire= +
Driver side:
Passenger side:
1)Green wire= -
Take care,
George
