Need help with S Type push in compartment by radio
hey guys, on my mothers s type, the push in compartment doesnt works automatically anymore. i got it out and i dont see anything wrong with it. i made this video to help explain. thanks!
Jaguar Compartment :: 100_1080.mp4 video by tonyvisone - Photobucket
If it's the early (1999-2002) car then I've seen a few threads.... may have been on Jaguar Forum.co.uk • Index page and may take a bit of finding so think of every word you can for the Search features on this & that site.
The cassette cubby has a little lever in the bottom rear that flips back and forth and latches/releases. If the part is missing it is down in the lower component section or behind the radio and A/C control.
You can buy a used one (any color) and put your colored faceplate on the operating unit. Or you can disassemble the working one to get the lever for replacement.
I even got a wrong one (RHD) and swapped the faceplate so I did not have to re-order the correct part.
I don't know if the 'telephone presenter' unit uses the same 'latch/release' lever so you will have to determine that if you get a used one from a salvaged car.
bob gauff
bob gauff
bob gauff
bob gauff
another update and question--- the part came but it came in the frame..... it looks like the screws that hold the frame in come from under it (and possible above too) where i cant get them unless i take the whole dash apart... can i removed the cassette holder only and put it in mine.... well i know i can, but will it work? any tricks to wind it up or just put it in? thanks
upon receiving the new item, i realize that the frame in the car is missed that back tab that holds the compartment. all of the screws come into the frame, so theres no way for me to get to them. the level that holds the compartment is the same way. i was almost thinking i could rivet the lever on..... any suggestions?
Received 6,310 Likes
