Need help with S Type push in compartment by radio
Old 01-10-2012 | 01:38 AM
tonyvisone's Avatar
Default Need help with S Type push in compartment by radio
hey guys, on my mothers s type, the push in compartment doesnt works automatically anymore. i got it out and i dont see anything wrong with it. i made this video to help explain. thanks!
Jaguar Compartment :: 100_1080.mp4 video by tonyvisone - Photobucket
Old 01-10-2012 | 06:29 AM
joycesjag's Avatar
Sorry Tony, I can be of no help on this one. We do not have that compartment.
Old 01-10-2012 | 09:01 AM
JagV8's Avatar
If it's the early (1999-2002) car then I've seen a few threads.... may have been on Jaguar Forum.co.uk • Index page and may take a bit of finding so think of every word you can for the Search features on this & that site.
Old 01-10-2012 | 11:05 AM
tonyvisone's Avatar
ya its a 2000..... thanks 4 the advice. i couldnt find it on that forum but made the same thread...
however if anybody has any advice post it! thanks
i saw some on ebay for like 30 bucks, but i cant see anything wrong, so im wondering if theres a certain way to put it in or what
Old 01-10-2012 | 02:49 PM
JagV8's Avatar
You probably have to use Search and be persistent.
Old 01-10-2012 | 03:16 PM
police666's Avatar
i think its called the cassette storage box
Old 01-11-2012 | 08:26 AM
tonyvisone's Avatar
thats one of the things i tried, but no luck
Old 01-11-2012 | 08:28 AM
tonyvisone's Avatar
i even tried spelling it wrong lol
Old 01-11-2012 | 10:52 AM
police666's Avatar
i'm not quite sure how it works but when it's in the car does it push in far enough to turn the wheels enough to release it to spring out ? maybe the cogs have slipped ?
I cant check on mine cos i nav there instead
Old 01-11-2012 | 11:18 AM
motorcarman's Avatar
The cassette cubby has a little lever in the bottom rear that flips back and forth and latches/releases. If the part is missing it is down in the lower component section or behind the radio and A/C control.
You can buy a used one (any color) and put your colored faceplate on the operating unit. Or you can disassemble the working one to get the lever for replacement.
I even got a wrong one (RHD) and swapped the faceplate so I did not have to re-order the correct part.
I don't know if the 'telephone presenter' unit uses the same 'latch/release' lever so you will have to determine that if you get a used one from a salvaged car.
bob gauff
bob gauff
Old 01-11-2012 | 01:25 PM
tonyvisone's Avatar
okay thanks bob.... i didnt realize there was a piece on the bottom. ill have to look at mine and then probably buy one off ebay for like 30 bucks
Old 01-11-2012 | 01:37 PM
The latch mechanism is not on the bottom but just inside the rear slot on the bottom.
bob gauff
Old 01-14-2012 | 12:16 AM
tonyvisone's Avatar
i just bought one off ebay for 35 bucks. ill post how it goes. thanks
Old 01-21-2012 | 12:06 PM
tonyvisone's Avatar
another update and question--- the part came but it came in the frame..... it looks like the screws that hold the frame in come from under it (and possible above too) where i cant get them unless i take the whole dash apart... can i removed the cassette holder only and put it in mine.... well i know i can, but will it work? any tricks to wind it up or just put it in? thanks
Old 01-22-2012 | 02:18 AM
tonyvisone's Avatar
upon receiving the new item, i realize that the frame in the car is missed that back tab that holds the compartment. all of the screws come into the frame, so theres no way for me to get to them. the level that holds the compartment is the same way. i was almost thinking i could rivet the lever on..... any suggestions?
Old 01-22-2012 | 09:38 AM
It's fairly easy to pull out the console and then you can change the whole thing.
You might find something in the audio section if you can't find it here.
Old 01-22-2012 | 10:02 AM
You need to remove the entire radio, A/C, cubby assy and disassemble the individual units.
bob gauff
Old 01-22-2012 | 10:00 PM
tonyvisone's Avatar
i really dont want to pull the whole dash out, theres no other way??
Old 01-22-2012 | 10:38 PM
tonyvisone's Avatar
how do i get those out?
heres a labelled pic of the dash to make it easier
Old 01-23-2012 | 03:37 AM
JagV8's Avatar
If Bob says that, why not just do it.....
Quick Reply: Need help with S Type push in compartment by radio
