Need help with S Type push in compartment by radio
I removed my unit and it is easy just remove your cover “D” on both sides and the one at the bottom and you will find bolts under them. Now to remove the unit you will need to put your shifter in “D” to do that. Do not pull on the unit hard because you have wire in the back for the radio and heat & a/c. I removed the shifter ball to make the job easier. I hope this helps.
I guess I was a day late and a dollar short on this one….
#28
Received 6,330 Likes
It should, have a look here https://www.jaguarforums.com/forum/s...003-faq-36719/
this is the later car but I believe that it is the same set up.
