Need help with service Please!!!!
I was stupid and pressed on my park sensor on the rear bumper and two sensors went in, not completely but its half-way in. How do I get it back to its place? If I have to take to the body shop or a dealer, how much would I be looking at as per labor?
I want to change my driver door mirror cover, how do I do that.
somedude, I have just read up on this. You may get lucky, lay on your back reach up behind the rear bumper feel if you can locate the sensor and wire connection, if so it appears to be a twist in type of sensor.
If you cannot feel anything then you are bumming because the rear bumper skin has got to be removed and that my friend is not a fun job!
I do not know if you will be able to repair the sensor(s) or not but a replacememnt will run you about $115.00. If the sensor pushed in that easily maybe try a dap of hot glue on a dowel and pull it out, although I do not know if that would harm the sensor. BTW I can see someone doing that to 1 sensor but 2???????
About your mirror cover the inside door trim panel will have to be removed and the whole mirror will have to be removed to work on it. IMO If the the mirror cover is damaged could you use chrome covers that stick on with 3M tape to cover, available through Mina Gallery or EBay?.
LilaJagHubby
10-06-2015 02:56 AM
