need to remove front seats on 04 S
Pretty straight forward, remove the plastic bolt covers, The seat bolts are a Torx type bolthead, I was able to use a 12 point 10mm socket. I found it easier to remove the back bolts first then recline seat all the way back then undo the front bolts. Carefully pry the plastic seatbelt cover off, there are little ear tabs that will break easily remove that bolt which is a Torx as well, I was able to use a 1/4" allenwrench to remove that bolt. Flip seat sideways remove the wiring harness. Done..... On the passenger seat there is an extra wire harness behind the plastic seatbelt cover for the airbag sensor. I do not know the Torx sizes, sorry.
Easy job to do, I just removed ours a few weeks ago.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
