need a shift knob for a manual tranny Stype
hey guys so my shift knob on my 03 manual tranny S-type has been loosing some color and now the leather is falling off in pieces and i wanted to ask if anyone can help me find one. Im scared to even call the dealership because knowing their prices i dont even want to ask...btw its a tan color. ANY help will be appreciated thank you..
Also how can i remove mine?
I also have a 03 with a manual transmission. Had the same problem with the shift knob and could not find an aftermarket replacement. As you probably know, the knob is not the screw in type but more of a box within a box connection. I ended up buying the knob from the dealer ($125). Have had good luck with the manual. Unfortunatly Getrag does not support a parts program for the transmission. If you do have trouble with gear engagement have a transmission shop check the linkage which is often the problem.
Have not had that problem. Sounds like something other than the transmission. I try to fill up around the one quarter tank marker. I seem to recall that the fuel pump is in the tank, and if you run a fair amount at the empty mark, you can damage the fuel pump as it could suck air. This might be your problem.
srjag did you check with ken@britishparts.com ? He advetises here and is a wealth of knowledge. He is not a Jaguar dealer.
aholbro1
08-05-2021 05:02 AM
neruda
10-18-2015 01:19 PM
