Need some quick help from techs please.
Ok, SOOO, when I last left off, my 2000 Jaguar s-type was givving me codes p0340 and p0341 and a maf code. I fixed the maf code and went through every step to fix the cam codes. After everything they are still there. As a final test, I cleared the codes waited about an hour and hooked up my scanner. The codes were cleared. I let the vehicle sit about a week and hooked my scanner back up, the codes were there again. So I decided to get a new pcm.
Well, I got it today and the company shipped the donor car's keys with the pcm and now I'm wondering, do I need to use those keys? I'm pretty sure the BCM or GCM control the key codes on the s-type but I don't want to mess up and have to take it to a dealer to get it reset if I get locked out for using the wrong keys!
So, use my existing keys or the keys they shipped with the pcm?
Thanks!
Thanks!
Have you followed the advice on various web sites, such as those below?
http://www.obd-codes.com/p0340
and http://www.obd-codes.com/p0341
I'd be very reluctant indeed to swap a PCM. (Not saying you're any different.)
This pcm has been subjected to many removals while the battery was hookep up and probably more damaging actions.
