New best ET for me (13.025) in 1/4 mile
Old 10-27-2011, 09:13 AM
Bacardi 151's Avatar
Originally Posted by Michael Star
Is the 3lb not worth it?
Like anything else, it's compared to what...IMO, it's not worth it unless you DIY install it...I would of rather of spent a few hundred dollars more and gone nitrous as I believe you get better results and it's safter for the motor assuming you're displined enough...
Old 10-27-2011, 10:40 AM
bfsgross's Avatar
IMO, the 3 lb. is definitely worth its weight in gold. If coupled with nitrous...no one can touch you. I wish we lived near each other so yas can sample how a 3lb STR pulls out of the hole...like she has 3:73's in the rear. Remember when we all pondered the prospects of lower gears? My argument is; not only do we not need lower rear gears, but we'd do better without. The trans. is geared just right for intake, exhaust, and pulley combos...big trq. moving heavy metal without excessive wheelspin...awesome for mid to top end runs too. An LSD would be nice though.
Bacardi 151 (10-27-2011)
Old 10-27-2011, 11:05 AM
3lb pulley vs stock pulley? yes, it's worth it and worth it's weight in gold...
If coupled with nitrous, is a different debate all together...You can't "turn off' the pulley...The bads are higher than OEM intake temps, possibly pulled timing, higher boost, you may be ever so slowly decreasing the life out of the stock motor everytime you do WOT run...
Nitrous while is most likely even more damaging to the motor and probably also your transmission due to the huge increase in TQ bring it well over it's hp limits...You usually don't use spray all the time, usually only 2nd and 3rd gear over a rpm window...Yet you get colder than OEM intake temps and usually an increase in timing. If you're displined enough to not use spray during every WOT run, I believe you do less damage to the motor than you if you had a 3lb pulley...
Stacking a pulley with nitrous is a scary thought because two offset eachother...If you're going spray, better to keep the stock pulley and if you want more power, simply up the spray...IMO...
Old 10-27-2011, 11:21 AM
bfsgross's Avatar
Bacardi, you made a lot of sense. Def. not do both.
Old 10-27-2011, 11:28 AM
Michael Star's Avatar
I keep thinking 1.5lb pulley and meth
Old 10-27-2011, 11:59 AM
bfsgross's Avatar
3 lb. w/meth? The meth will both make power and cool her down from the 3 lb.
Old 10-27-2011, 12:13 PM
From what Ive read, the 3lb helps more with mid range but you lose top end.
  #28
Old 10-27-2011, 12:21 PM
bfsgross's Avatar
Agree, but include "bottom" to midrange. I in particular, don't care too much about top end. As for the street driving, the bottom and mid is where it's at. Ohhh...to have a twin screw....?
Old 10-27-2011, 02:20 PM
Ya I keep thinking about that as well.
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
vsol
08-29-2018 09:46 PM
08Z06
10-24-2015 05:46 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: New best ET for me (13.025) in 1/4 mile
