New to the forum, 05 S type 3.0
I have a 2005 S type 3.0 with 45,000 on it. The car is great, but I do have a couple questions. Every time I am at speeds of 50 to 70 mph the engine and tranny sounds fine, but when I press on the accelerator slightly it makes a whining/whistling sound. When I accelerate harder it goes away. If I take my foot completely off the accelerator, the sound goes away. Any ideas?
I also have a 2005 S Type 3.0 with about 45K on it and it does the exact same thing so I would also be interested in knowing what this is. I've owned the car for a year and a half now. At first I thought it might just be intake noise but I am starting to think it might be the rear end / differential.
My car is under "Select Edition" warranty so I was going to dealer and ask them to check it out but I have this feeling they are going to say it's normal, just like they did for "the lurch" which was fixed by the emissions recall re-flash.
Mike (Member Name "carelm") had this issue in late 2009 and had it repaired under his Select Edition warranty. It is described as a rear-end whine at about 60 mph, and the fix is described in Technical Service Bulletin TSB 205003. The rear axle assembly and axle housing bushing must be replaced....
Hopefully Mike will see this thread in the next day or so and will chime in with more details....
Mike
I think my 03 Stype has it too. When I come to a slow stop, it's like a get a little bump on the tail end of the car! Not always, but sometimes. I read in the forum that it was a computer programming issue in the tranny, not the tranny itself. I'd be interested in what the dealer actually did to correct it and what the cost might be. I have extended warranty but it does not cover the electrical side of the transmission. Thanks
stanjag
08-30-2015 10:35 AM
