New to jags... couple questions!! NEED HELP
Guest
Posts: n/a
Hey guys, i'am thinking of buying a 00 s-type with only 90,000km for a great price. But anyways car is from toronto, yes i checked for rust and everything. My questions are they reliable? How gas mileage? Maintence? parts $$? Whats themost common problem? Riding on 20's comfortable?I'm asking because my old car was a 1995 tsi awd andya had a quiet a few problems on it. But thats mitsu and this a jag so obivously i will expect much better reliablitity.
Guest
Posts: n/a
RE: New to jags... couple questions!! NEED HELP
yea proper maintence was done on thatcar, has low km's too. I just drove the car everything seem fine looked really mint. No rust or anything, coils were done recently too, which i heard is a problem with these cars. What should i look for though on these cars? What usual problem? By the looks of things everything looked mint, but i do the usual check up and don't know much about these cars.
if its equipped with V8. ask if timing chain tensioners have been replaced. if not, look into updating the timing components. the original tensioners were plastic. they would break off, and in turn a chain would break, valves would bend, $5000 (USD) in work would result.
pay attention to how hard it is to shift out of park on an incline. there is an updated gear selector lever to fix that. around $700 (USD) to fix that.
sway bar bushings will make noise. original window regulators break and the window won't go up.
thats all thatimmediately comes to mind
How about post a price, and I'll tell you if it's a steal or not! Check for the wheel bearings! +1 on the window regulator thing that NTI talked about as well as the shifting out of park! Check out the interior, as it's really shabby. The roof cloth tends to fall down on some, and if it's plastic, it can break...so check it! Other than that, if it's 90K km, and not miles, than the car has really good mileage. Still doesn't mean that it may be over-priced!
If you looked teh car over real well and it looks good to you, 2000 isn't too old and there's no like garanteed problems. If it looks good to you you should jsut buy, especially with the great milage (Assuming it's a good deal).
But then again your talkin to someone with two used jags that have never had a single problem, so I'm biased.
Although my dad's xk8 check engine light is on
Guest
Posts: n/a
I have an 03 STR with factory 18's and I wouldn't go any bigger (but that's just me) because I like a nice ride. The 18's are a little hard on the bumps but not too bad. 19's or 20's I don't know. I drove a friends G35 sport with 19's on it and it was like driving a truck. My car fells like a Roll's after that. It's not bad in the winter but it is light in the rear end so you have to be carefull.
VicJag, S Types are nice (and you might have already boughtit by now) but definitely get a warranty!
Below is list of things my Warranty has already paid for since I've had my 2000 S Type 3.0L.
__Brake work (61Kmi)
__3tires replacedat 63Kmi (fault in valve stems - dealer'sfault when tires replaced at 58Kmi)
__New air-conditioning compressor at 68Kmi
__New belts/hoses at 68Kmi (Warranty only covered labor)
__Loose side marker lights(69Kmi)
__New coils at 72Kmi
Guest
Posts: n/a
Those problems don't seem too serious, because my bro is a mechanic, brakes are easy, tires easy, side markers seemed you had some minor problems. The thingis this warranty im getting doesn't seem like a good system. You guys really recommend warranty even though i always maintain and baby my cars to the fullest. Are these cars that un reliable
WinterJag
16
10-09-2015 07:49 PM
