New (to me) 2007 S-Type
I just bought a 2007 S-Type.
Now I have 2 cars and they are both Jags. So, I guess I am a Collector, lol.
I have a couple of questions. First, Where is the paint code (sticker) located?
And, Is it OK, to spray some WD40 into the ignition switch? It sometimes will not start or turn off. The key won't turn.
Thanks In Advance for any help.
the paint code should be on the door pillar...a sticker on the drivers side..if it is missing then you would have to use the vin I would think....I do not know about the wd-40, probably ok just a squirt...the ignition switch has a stiff spring to start out with..it could be a worn key or tumbler issue also....plenty of knowledge here on this forum....you will get the answer you need I am sure....maybe use the search bar about a sticky ignition switch also....nice car by the way...you did well
Vistacom1 (06-23-2018)
Quote this for sure and to add while I was researching a drain on my battery one of the culprits to check is the switch not shutting down even with the key out that was said might be from sticky lube inside. It wasn't the drain in my case but something I stopped doing is having the rest of my keys weight swinging off the remote that is also said to damage the switch.
4bizonly
04-06-2012 01:46 AM
AccAuto
07-05-2008 10:54 AM
