New member here : need help and advise on my 2001 s-type
Hi everyone, i have a 2001 s-type 3.0, bought it used last year with 48,000 miles and i just put 10k on it. Car still drives smooth but i'm having some electrical problems just two weeks ago.
1. Both my front and rear passenger side window don't work no more, the windows come down anytime i hit a pot hole or drive on rough road. i have to park and manually pull the glass up. My rear right passenger door does not open no more since last week.![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
2. my check engine light comes up randomly, mostly after i fill up my tank, sometimes it stays for a week or couple of days. it only comes on when i fill up my tank (not everytime though)
3.I see water at the spare tire place and i don't know where it comes from.
4.I dont know if there's something wrong with my antenna, but anytime i pass through a tunnel or overpass, i loose reception when listening to radio
5.My driver side power seat does not move foward no more, i hear the motor make noise and the seat barely moves.
My mechanic have a 2000 Lincoln LS so he takes care of everything and gives me good price since he's also a friend, but when it comes to these electronics, there's little he can do.I have not visited a Jaguar dealer since i bought the car and i'm planning to visit Land Rover/Jaguar of Manhattan,NY, anyone used their service before? Is there another Jaguar dealer you'll recommend in New York or the Tri-state area you think have good service and great prices?
Also if there's a retailer i can get the parts for cheap, i would be happy to know. I am also open to any step by step tips if i can fix any of the problems myself.
Thank you for reading.
Wow ! you are not having a good time !... The windows sound like the lifter is broken, these are plastic and a known weak point, take off the door card and have a look, you can buy new lifters but keep your old motor as these are a separate buy! The engine light may be due to the evap system, are you overfilling your tank?
Water in the boot (trunk) is common fault - check your lid seal, reseat it with silicon and then clean and coat the seal and lid surfaces with a silicon spray - this will help it reseal correctly (this is what the dealers do)
The seat may just be the lead screw followers fitted to the seat slipping or worn - if you can hear your motor working. have you tried a different setting in the seat memory to see if the seat works correctly to this point - it may be you have wear at on specific point. So somewhere to start - hope it helps.
About the seat, i tried the two saved memory positions and only the steering wheel moves. i checked under the seat if something was blocking it but i see nothing, but i found out the seattries to move from left to right.
I don't remember overfilling my tank, but since the check engine light doesnt come everytime i fill up, i'll just forget about it, maybe it's just a sensor causing this.
Or buy a cheap reader , its often worth the money just so you can see what is going on. I often get an engine fault light up and its the mass air flow. often resets itself and does not cause a problem - but before I bought my scanner I used to worry about what was going on
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
These seem to be extremely common problems with the older S-Types. I have been forced to fix the back left window and the front left side too. There is a stupid plastic block that holds the window. The block breaks and The dealer wants to change the whole assembly instead of just the block. The plastic Blocks can be got hold of over here in Germany but it seems as if not many people know where to get them. The first door I repaired myself after getting the whole mechanism from England (costed half of what the Germans wanted for it). The second time I managed to get the block for a very reasonable price and swapped it in myself. I wish I could find a cheap way of sorting out the locks as I have had no luck there yet.
No need to wait for a repeat .. the fault code will be recorded in the memory, so if you are near auto zone - pop in and get it read.
Or buy a cheap reader , its often worth the money just so you can see what is going on. I often get an engine fault light up and its the mass air flow. often resets itself and does not cause a problem - but before I bought my scanner I used to worry about what was going on![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
I'll just chime in with a quick hint. Do a search here on trunk leaks. There are a few threads that talk about locking yourself in the trunk with the help of a friend, an no I'm not kidding. I would make sealing and drying out your truck a priority. One of the main fuse and relay boxes is in the trunk adjacent to the battery. As we all know, water and electronics don't mix. The water issue just might be the source of miscellaneous things not working except the windows. The windows are a common issue with your year and should be an easy fix...
http://cgi.ebay.co.uk/Jaguar-S-Type-...#ht_1842wt_913
direct link in English
direct link in German
http://cgi.ebay.co.uk/Jaguar-S-Type-...#ht_1961wt_913
Just replaced a regulator on mine and bought the whole thing for front passenger side with motor for 58 dollars plus shipping on Amazon. Used a Lincoln LS type for the replacement. Those plastic pieces are the issue so if you find the shipping costs might be to much from UK, and since you will have to take the door panel off already to replace, might want to consider a new one. Your call. I would buy a pry panel removal tool. got mine at Auto Zone. Figure I am eventually going to change all 4 regulators at some point so tool will come in handy.
