New owner of 2001 Jaguar S-Type...need a little help please!!!
This is what i bought from a friend for a fairly good price but it has a few problems. First i know it has 2 bad O2 Sensors and a bad catalytic converter but this is where i need help from the EXPERTS ...what happens is, lets say i first turn the car on during the day everything works fine but as the day passes and I'm driving around the car begins to accelerate funny even to the point of not getting past 20MPH, what i mean is when i push the pedal i can see my RPM's go up but the car won't move or will move really slow, also when i go from P to D i have to wait a few seconds to sometimes more than 10 seconds for it to start moving, I have taken it to 3 different mechanics and all 3 have said different things .
The first one said outright that i need a new transmission, the other one said it could just be some sensors and the last one said i just needed a tranny tune up. BTW my car smells like burning oil too from inside, i mean obviously something is wrong but i just want to know WHAT . Does anyone know a good jaguar mechanic in San Diego, CA? also why does this get worse the more i drive but not during a cold start? Thanks everyone for your time.
It will drive badly with those faulty parts. The car is simply unable to control its fuelling so you risk doing major further damage. Also, those faults will make any other diagnosis somewhere from hard to impossible. I don't understand why you have not fixed the known faults.
They may, but if the acceleration problem is something else I doubt you could diagnose it until you have fixed them.
You say "a" bad cat. The way the car is now fuelling/running you do realise the other cat is at risk, I hope.
If you have time but a shortage of money I'd get the workshop manual (ebay $6) but especially an ELM327 (ebay $20). Then, read a lot about how the feedback stuff and OBD-II all hang together so you can watch your cars sensors and understand what's working and what isn't. You only need to avoid fitting one thing to more then justfy the minimal costs.
Burning oil smell inside cabin points to the IMT O-Rings. The '01's differ slightly from the '05's (location wise) which I have had to replace (along with many other members here).
They are located on the intake manifold. The O-Rings allow oil to drip onto the engine causing the burnt oil smell. Along those lines excess oil is also being burnt and sent through the O2 sensors and cats.
Hope this helps.
BTW, I would start by replacing the O-Rings, cheap and easy! Get a JTIS on ebay or www.alldatadiy.com subscribtion to aid in replacement.
Hope this helps.
The burning oil smell may also be cooking transmission fluid. There's a distinct difference between trans and engine oil odors. He mentioned it takes time for the transmission to engage after shifting from Park to Drive= Burnt trans. oil odor + slippage= either cooked clutch packs and/or failed transmission pump. My opinion is toasted trans= rebuild or swap. Not enough info. to determine alleged catalytic converter-O2 sensor issues.
Nice ride even though she has 108k on the clock. If purchased at a low price= worth to rebuild/swap tranny, etc.
Agreed. It's a big job replacing or rebuilding a tranny. I've done it a couple of times and I ended up having to buy new tools and sending some stuff out anyway.
Cheaper to get it done.
Go here:
http://www.atra.com/
Go here:
Your symptoms sound exactly what our '01 was doing and the tranny was the culprit. Thankfully it was still under warranty, however the replacement tranny did the same thing but worse. At times would only go about 15 miles an hour for a little bit then would decide to take off when it damn well felt like it. Had a couple of short changing experiences with that. The 3rd tranny has been going strong for 7 years now.
After our dealer talked to Jaguar found out it was happening in some other 01 S-types also.
Car smells
I have 2.5 s-type with an emission smell in and around the car. HAve had O2 sensors replaced as it was using fuel (running rich) and this helped a little. I think I will replace the cats to see if this remove the odour. Has any 1 used non genuiune cats with success or failure??
