New STR owner with Cat converter and misfire problems
I know there are a lot of threads on all these topics, but I want to see if I have issues relating to one another. I have several codes P0205 and related pending codes for # 5 ignition coil. It was replaced 1 month ago when I bought the car, and now its at it again. Restricted Performance, poor idle, misfires, etc. Also my Cats are hot as heck in the tranny tunnel and you can feel it getting hot in the car.
I ordered Magnaflow # 55975 replacements and the shop I go to told me that they are not a fit because of an O2 sensor that is in the center of the cat itself and the magnaflows won't work. What can I do to get around this? I do not want to pay 1800 per cat from the "Cat" dealers...
Kind of stressed about all the issues since the car runs awesome aside from that. Fast car, rides like a dream!!! Just hoping someone can reach out to me to help me so I can stay a happy Jag owner.
I will update my signature later, but here is my cars info
2003 STR 4.2 Supercharged with 115k miles. No mods no swaps no nonsense.
I remember seeing posts from some member(s) who had to use extenders, but don't recall what Magnaflow cats they were using.
Anyway, my STR now has 75k miles and I have been assembling the bits and pieces so as to be ready for the day the cats begin to go. Magnaflow 99675 HM and a pair of (dirt cheap) extenders, just in case.
I recall a discussion about how an extender could, in effect, trick the ECU into believing these hi-flow cats to be (nearly) as good as the OEM's and not sensing an error. Final theory was that the flow of gases was greater than OEM, but the extender moved the sensor away from the mainstream, and located it where there was less oxygen flowing past in unit time.
Well, it's not MY theory, just A theory, from someone tying to explain an observed fact. As I recall, you were one of the people who had NO idea as to why extenders seemed to work.
Other than in a perfect world, oxygen is bound to be present from time to time, as the catalyst degenerates.
As I understand it, the Magnaflow hi-flow cats are way less expensive than OEM, but are less efficient and permit a higher flow-rate (and hence more power).
So, the exhaust gas passing by the after-cat sensor is moving faster than OEM and contains more oxygen. Not illegal O2 levels, but definitely higher than OEM. Net result - the ECU may decide that there is a problem.
An extender positions the sensor away from mainstream flow, where less gas passes by the sensor and less oxygen is detected in the sampling interval. It's cheating, really, but nothing too serious.
My STR came from California, so my ECU may be used to better days than it's going to see when the Magnaflows are installed. So, I'm taking no chances, especially as extenders are inexpensive and not illegal.
Any exhaust shop competent enough to install high flow cats, should be able to weld on additional oxygen sensor bungs to thread in your existing o2 sensors.
You can use 'extenders' or modified 'spark plug defoulers' on the secondary o2 sensors, to prevent cataylst efficiency codes from popping up when running high flow cats, or no cats at all.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
rootbeerlover
08-31-2015 03:37 PM
